Guys Just looking for opinions on what cylinders to run on the rears on the GTS's brakes. I'm running AUII onwards front calipers on BA-BF rotors, with VT stepped bore master cylinder, HG booster and HK-WB rear drums. Original HK disc/drum rear cylinders look to be 9/16". Am I better off running HK 9/16" or one of the drum brake (or HQ) sizes: 13/16" or 7/8"? It won't have a proportioning valve, apparently doesn't need it with the stepped bore booster. Any suggestions also on what cylinder brand to buy that won't be stuffed in 2 years? This car has not been used since the front end was totally rebuilt about 4-5 years ago and all the tie rod and ball joint rubbers are shot, don't want the cylinder rubbers doing the same! Edited by user Thursday, 14 February 2019 9:22:35 AM(UTC)
| Reason: Not specified |
The VT doesn't have a proportioning valve because the car would've originally had ABS.
I would stick with the 9/16" cylinders & matching shoes.
All HQ with disc front had 7/8" rear cylinders plus a proportioning valve.
Dr Terry |
Thanks Terry What did HJ have on the rear without the inline prop valve? I do have some old stock PBR 7/8” ones here from the 90’s that are not cheap rubbish. Also not all VT had ABS? Or did they? Can't remember. Or did export ones have no ABS? I thought all VT master cyl were the same, the ABS ones used the extra port and the non-ABS had it blanked with a plug. I also thought they had an inbuilt proportioning valve in the VT master cylinder. Edited by user Thursday, 14 February 2019 12:17:00 PM(UTC)
Actually all HQ-WB (exc. 4 wheel disc) have 7/8" rear cyls, regardless of disc or drum at the front. The only HQ/HJ without a proportioning valve are the 4 wheel drum variety. There are some VT/VX without ABS & these have a proportioning valve either internal in the master cylinder or the load-sensing style on the rear of utes etc. Dr Terry Edited by user Thursday, 14 February 2019 3:11:50 PM(UTC)
Cool. There is only one VT master cyl though for all applications? I'm pretty sure that is correct. I guess I have two options, find some quality 9/16" cylinders or try some 7/8" and possibly have to fit a HQ prop valve inline if I get too much rear braking. The VT master cyl definitely has no internal proportioning valve? |
The best rear cylinders are to have yours re-sleeved in stainless steel & use good quality Australian cups & boots.
From experience, it's best to fit the 9/16" rears, they just work better.
So I guess it's just the VU-VZ Utes that have a load-sensing proportioning valve connected to the (live) rear axle & none in the m/cyl.
Dr Terry |
Will see if I have any 9/16” ones here. I think my Woodsman Green Monaro has some. The brake place told me that VT cylinders have a prop valve internal but it doesn’t look that way to me. |
Joined: 11/09/2016(UTC) Posts: 234 ![Australia Australia]() Location: OZ Was thanked: 29 time(s) in 27 post(s)
My VT - VZ Ellery's shop manual says VT - VY m/cyls have a built in proportioning valve. It is behind the hex plug at the front end of the cylinder.
I forgot these were arse about compared to a HK-HG, wasn't looking at the front. Brake place told me to use 7/8" due to the VT cylinder having an inbuilt prop valve, but I have grown to trust Dr Terry's experience. What I might try to do is use the 7/8" ones I have and see how it goes, but try and find some old 9/16" ones too and get them rebuilt ready to use if I have to. Terry, the flare adapters, is it worth using them? I have to make up all new lines for the HK, and rather than use the distribution block down on the subframe I was intending to use the two front circuit outlets on the VT master cylinder, and also make up a new line for the rear that suits the VT rear circuit outlet. I cut pipe ends off a VT to get the nuts. So some of the car will have the old style flares, some will need those like what are on the VT cylinder. Not sure what Rodtech have on the hoses with the Ford calipers. Should I use all older Holden style flares and adapters or just have different flares on each ends of the lines? On the same matter, the VT lines look larger than the HK ones, so will the VT nuts work with HK size tube? If not I guess it means adapters! I think the VT cylinder has 12mm port for the rear circuit with ball flare and the front circuit has 2 x 10mm ports with same ball flare. Edited by user Thursday, 14 February 2019 5:59:46 PM(UTC)
Does anyone have a catalogue that shows what the difference is between P10046 an P10046G? Both say they are 7/8" rear wheel cylinders to suit just about everything from HQ onwards. |
So many questions first thing in the morning !! Firstly the difference between P10046 & P10046G is that the G version is "built to a higher standard". It's more of a marketing idea where the G cylinders are actually plated a gold finish.
I think it was a PBR thing where there were so many cheap Asian-sourced cylinders on the market, all using the same part number, they needed differentiation. They are otherwise interchangeable.
AFAIK all the brake pipes used in VT-VZ etc. are still 3/16" even though the pipe nuts have metric threads. I have done plenty of conversions which have an SAE pipe nut at one end & a metric pipe nut at the other. Nothing wrong with that & in many cases it works out neater.
On the subject of so-called proportioning vales, they don't actually do any proportioning. The front/rear brake bias is controlled by the ratio of the cylinder sizes. This is why I prefer the 9/16" rears.
The proportioning valve is actually a limiting valve, where it allow unlimited braking up to a certain point & then limits the pressure to prevent rear lock-up.
Dr Terry |
Thanks Terry
I have a P10046 and a G version from the 90's. I'll try them and rebuild some 9/16" ones ready to go if I get too much rear braking. This car has to have a brake test for Engineering so it has to be right, so I don't mind a bit of work to get it right. The car will actually have a better front to rear weight ratio than the original 307-auto-banjo-a/c-steer would have had. I reckon I've lopped off near to 60kg off the front of the car with:
Alloy heads Alloy intake Alloy water pump Rodtech front end VT master cyl SD508 type compressor Territory power rack LS style power steering pump No fuel pump. BF electric engine fan
And the rear getting a 9" rather than a banjo will be heavier.
It must be an optical illusion due to the brownish colour of the VT lines rather than grey on the older ones. Makes it easy then, will just make up new 3/16" lines. |
Joined: 19/02/2019(UTC) Posts: 1 ![United States United States]() Location: Massachusetts
he cylinder mounting studs are horizontal so HK through to HZ?? cylinders will bolt on ok. To run this make sure you have the clearance 'dent' in the inner guard. Not all have it, mine doesn't. The one I run is a smaller factory booster. It's off a HK but not sure what model. I have to re-drill the mounting bracket to lift it slightly to clear guard. The cylinder mounting bolts are diagonal so commodore style cylinders bolt straight on. Edited by user Wednesday, 5 January 2022 10:21:04 AM(UTC)
Mine has 6/68 front so is smooth on driver side inner guard with dent for straight booster. I’m using a HG disc brake booster with special adapter for VT master. I would have rebuilt the booster with a later UC nose on it if I was using an earlier Commodore cylinder but easier to do it the way I have. I need the VT cylinder for the flat top and big bore on t front circuit for the 4 pot calipers. The standard Rodrech front end uses VS calipers which would have used the earlier cylinder but this has AU2 onwards calipers. |
Dr Terry, back to this topic. Been looking at my HK's rear end again, got some stuff out of the way to get to it. With the HQ-WB rear brakes, if I use 9/16" rear cylinders will it simply work by using the HK-HG shoes (to suit the small cylinders) with all the rest of the HQ-WB stuff inside the drums? |
Originally Posted by: HK1837  Dr Terry, back to this topic. Been looking at my HK's rear end again, got some stuff out of the way to get to it. With the HQ-WB rear brakes, if I use 9/16" rear cylinders will it simply work by using the HK-HG shoes (to suit the small cylinders) with all the rest of the HQ-WB stuff inside the drums? Simple answer is YES. The shoe profile is different to match the smaller wheel cyls, which have no push rods. All of the other hardware is the same. Dr Terry |
