Dr Terry Online
#1 Posted : Sunday, 27 September 2026 10:48:14 AM(UTC)
Hi Guys.
This query involves the change of VIN style at the introduction of the VY series. At VY the VIN changed from the older style with a 6H8 prefix which had been around since the intro of the 17-digit "ISOVIN" (@ VN) to a new type beginning with 6G1.
AFAIK this began precisely at the start of VY production which was the start of MY03 model year (Sept 2002). At this same time the WH Statesman & Caprice which were still production thru to the release of WK in April 2003. So these later WH also got the newer 6G1 VIN for those last 8 months or so.
But what about the V2 Monaros? V2 Series 1 was released in Dec 2001 & was replaced by the V2 Series 2 in Dec 2002.
Did Monaros built between VY release (Sept 2002) & December 2002 get the newer MY03 VIN.
It would make sense on the production line that all of the cars which were built on the same basic platform received the same series of VIN ID. Could you imagine the confusion if the Commodores & the LWB cars got the newer VIN but the Monaros built on the same line on the same day got the older VIN.
So which is it? Does anybody know of a Monaro built in this timeframe that would answer the question.
Edited by user Sunday, 27 September 2026 11:16:17 AM(UTC)  | Reason: Spelling
#2 Posted : Sunday, 27 September 2026 11:53:56 AM(UTC)
Originally Posted by: Dr Terry Go to Quoted Post
H...................... Does anybody know of a Monaro built in this timeframe that would answer the question.
I don't know the answer but would be asking Norm Darwin if he knows
#3 Posted : Tuesday, 29 September 2026 10:40:56 AM(UTC)
Ben is the one to ask Terry. It also all depends upon when tags were stamped and/or embossed. Before or after the build. For example, what I mean is during the 70's Pagewood put the VIN tag on at the very end of the VAP. Whereas Acacia Ridge put it one in the BAP prior to paint. Meaning they were predicting completion. Normally that wasn't an issue, but if you were at say 29th August and you put the BODY and VIN tags on the body prior to paint, using say a C for 1973 in the VIN. But the car is delayed and not completed until say 10th September. So instead of having a D for 1974 it has a C. But the Safety Compliance Plate will have a 1974 build on it ie 9/73.
#4 Posted : Sunday, 4 October 2026 5:34:21 PM(UTC)
Hi Terry,
The VT/X Lumina at Brirdwood motor museum has a 6G1 ISOVIN from memory.
ALL V2 Series I have the 6H8 even though they were being built during VY
Pontiac GTO are 6G2.
I assume the VE G8 will be the same.
The Chevrolet SS will be 6G1, just like middle east cars.
As you know 6 is Australasia, 8 is Holden, 1 is Chevrolet and 2 is Pontiac.
Why GMH became Chevrolet in VY I cannot answer.
#5 Posted : Sunday, 4 October 2026 5:57:15 PM(UTC)
The VT/X that is at Birdwood motor museum is a 6G1 ISOVIN from memory.
All V2 series I are 6H8
All Pontiac GTO are 6G2, G8 will probably be the same
All middle east are 6G1
US Chevrolet SS and Caprice will be 6G1.
6 = Australasia
H = Holden
G = General Motors
1= Chevrolet
2 = Pontiac
8 = Holden
US built Chevrolet are 1G1
Pontiac are 1G2.
Not sure why they changed to US ISOVIN and made our plants General Motors and Chevrolet division.
Warren
8D11PCH2 Offline
#6 Posted : Sunday, 4 October 2026 10:48:08 PM(UTC)
8D11PCH2
Byron, Ben told me Acacia Ridge issued the VIN Tag at the end of the assembly line. It was only the Body ID Plate that was fitted in the BAP prior to paint.
#7 Posted : Monday, 5 October 2026 10:13:08 AM(UTC)
It depends on when in the 1970's. At some stage after they started using the PSN as the body number they began putting the VIN tag on prior to paint. The BODY tag went on bare steel so has body dip and red lead over it but only paint on the VIN tag. Appears to start early in 1976. Pagewood started putting the body tag on pre-paint too once they stopped putting a body number on the firewall mid 1978.
#8 Posted : Monday, 26 October 2026 11:06:52 AM(UTC)
Another twist, while at Trafalgar Holden Museum found a 6G3 VIN.
Also found a VY crewman prototype with a 6H8 VIN but it was the VIN from a WH Statesman, GMH must have used it as a donor VIN.
This page was generated in 0.065 seconds.
