#1 Posted : Thursday, 13 January 2005 10:05:57 PM(UTC)
Hi guys, I heard that ROH or some similar company is producing the original HR disc brake steel wheels, does anyone know if this is true or of a source I can aquire them from.
#2 Posted : Friday, 14 January 2005 3:42:08 AM(UTC)
ROH produce lots of different steel wheels. you should be able to order them from any ROH dealer.
#3 Posted : Friday, 14 January 2005 3:54:40 AM(UTC)
Hi Dre.
HD/HR wheels fit both disc & drum braked cars, there isn't a special wheel for disc brakes.
#4 Posted : Friday, 14 January 2005 10:32:01 AM(UTC)
You sure Dr Terry? I was under the impression the disk brake rims have "disk" (or disc) stamped on the back of them, and the drum brake wheels don't clear properly.
#5 Posted : Friday, 14 January 2005 6:55:46 PM(UTC)
Thansk Dr Terry, The reason I asked this question was that I was told on another forum that the offset was different on the disc rims and they had a small hole drilled in the rim to distinguish them, and just wanted to make sure I tracked down the right o
#6 Posted : Saturday, 15 January 2005 12:47:19 AM(UTC)
I think you'll find the disc brake rims are slightly different, why else would they put the small hole between two wheel stud holes to distinquish them from the drum brake wheels????
Peter
#7 Posted : Saturday, 15 January 2005 3:14:28 AM(UTC)
Hi Guys.
There are basically 3 types of HD/HR rims.
Type 1 - HD passenger, fits all HD passenger cars disc & drum (remember disc brakes came out with ball joint type suspension in July '65)
Type 2 - HR passenger, fits all passenger H
#8 Posted : Saturday, 15 January 2005 10:35:52 AM(UTC)
So thats why my copies of the HR adds list a wider track. Another thing I won't die pondering about.
Webby
#9 Posted : Friday, 21 January 2005 11:32:52 PM(UTC)
Well there you go, now we have all learnt something, Thanks Doc!
Peter
#10 Posted : Sunday, 30 January 2005 11:00:33 AM(UTC)
so back to the original question in a round about kinda way, does anyone know if they are being reproduced as a new item??
#11 Posted : Tuesday, 15 February 2005 7:50:28 AM(UTC)
I have heard this too, I have also heard that some of the caravan places may stock them and retail is around $45 per rim.
