#1 Posted : Saturday, 15 January 2005 2:25:19 AM(UTC)
Hi,
Got a HZ kingswood V8 wagon that Im taking in for a wheel alignment next week. A mate of mine told me that he took his in once and they told him they couldnt do it because the chassis had been narrowed by the weight of the motor on the cross member over the years, draging the side rails together just enough, as to run out of room it install shims on one side. Is this a common problem. Mine has limited shims on the passengers side. The wheel aligners who did my mates told him he had to spread the rails again. Would this be easy enough to do if required by removing the motor, and jacking the rails appart a few mm? Any ideas?
Thanks.
Kingswoody
#2 Posted : Saturday, 15 January 2005 5:06:58 AM(UTC)
well, I worked at holden dealer back in the seventies for a few years. I remember the hk, ht and hg used to sag the front end could not get the wheel alignment on them without working the crossmember over. Mainly on v8,s. We used to pull them straight on
#3 Posted : Saturday, 15 January 2005 9:53:15 PM(UTC)
I had the HQ V8 done in '94. It was sagged badly. They essentially jacked the motor up put it on a rack, cut the pillars and pulled them out, then rebraced and rewelded. It cost $1500 with complte replacement of springs bushes etc - made a hell of differe
#4 Posted : Saturday, 15 January 2005 10:41:04 PM(UTC)
NOLTEC SUSPENSION SELL A ADJUSTABLE FRONT LOWER INNER BUSH TO THAT WILL CORRECT ANY ALIGNMENT PROBLEMS
#5 Posted : Sunday, 16 January 2005 3:56:06 AM(UTC)
If you are going to go to that bother I would get a HZ or WB RTS front end get it done up and put it in. Look for one with no chassis number (they do exist especially in cars that have been repaired) the steering is so much better and your car is off the
