#1 Posted : Friday, 28 January 2005 9:09:55 AM(UTC)
Does anybody know of a rack and pinion set up for my HZ. i want to use a early c'dore rack.i called castlemaine rod shop and their racks uses LJ torana.i once owned an LJ and they are nightmare to steer with the rack on the front of the cross member with the wheels folding under like they do.
#2 Posted : Friday, 28 January 2005 5:03:01 PM(UTC)
Hi Jamie.
On the LC/LJ Toranas it's not the steering rack causing the incorrect steering angles, it's the suspension design itself.
Part of the problem is that the 'Ackerman'`angle wasn't set-up properly when the wheelbase was lengthened from
#3 Posted : Saturday, 29 January 2005 7:56:17 AM(UTC)
Thanks Dr Terry. I was looking at making the engine bay alittle neater.But i do have really heavy steering...Jamie
#4 Posted : Saturday, 29 January 2005 5:36:58 PM(UTC)
Hi Jamie.
Rack & pinion steering is no lighter than a box, it's all a matter of what ratio the gearing & linkage is.
If you go rack & pinion, you have to go power steer anyway, so just fit a power box.
#5 Posted : Saturday, 29 January 2005 10:59:50 PM(UTC)
Hi Dr Terry
Would a power steering box be suitable for an EK with HR front end?
