#1 Posted : Tuesday, 1 February 2005 5:03:26 AM(UTC)
Does anyone have any info on a good way to fit an air conditioning compressor to a 186?
Is the soultion to use a double pulley on the fan? (there doesn't seem to be room to fit one on the existing fanbelt without fouling).
Maybe someone can advise the best configuration?
Cheers.
#2 Posted : Tuesday, 1 February 2005 5:44:05 AM(UTC)
Take a look at a VB-VH 6 cylinder commodore - the A/C mounts low on the LH side of the motor (but may be too close to the rail on a torrie) or the alternative is a VK 6 cylinder, where it is mounted high up on the RH side of the motor, but it needs the 4
#3 Posted : Tuesday, 1 February 2005 6:35:12 AM(UTC)
Thanks Mick.
That's great news that I can bolt-on a pully to the harmonic balancer.
Could you elaborate on the 4 mounting bosses at #1 plug? I have a blue head but I guess it's not a late model as there are no mounting bosses in that area.
#4 Posted : Tuesday, 1 February 2005 6:36:46 AM(UTC)
Thanks Mick.
#5 Posted : Tuesday, 1 February 2005 6:46:20 AM(UTC)
The 4 bosses are around the plug hole in a square pattern - they are drilled & tapped.
If it's in the landrover, then do you have space beside the motor on the lower front LH corner?
If you do, it would be a better position for it.
Y
#6 Posted : Tuesday, 1 February 2005 7:37:05 AM(UTC)
Hi Nicko,
The bracket that Mick referred to to mount the compressor down low on the left can be seen here: http://gallery.oldholden.com/Qute/qute28
I hadn't fitted the second-row pully on
#7 Posted : Tuesday, 1 February 2005 7:46:59 AM(UTC)
Thanks Mick.
#8 Posted : Tuesday, 1 February 2005 7:52:10 AM(UTC)
Hi Nicko,
When I said that I'd swap bits, I meant the combined alternator/aircon compressor bracket and the adjusting bracket...I don't have a spare pulley at the moment...
Cheers...Dave
#9 Posted : Tuesday, 1 February 2005 8:10:13 AM(UTC)
Thanks Dave and Mick,
Dave, that photo is great, now I see how it should be.
Mick, I have plenty of space but most of it is on the RHS. I reckon it might fit under the alternator though, as you say this would be best.
One last question..
Guest (5)
This page was generated in 0.152 seconds.
