#1 Posted : Saturday, 18 April 2009 7:38:08 AM(UTC)
308 offset crank,?any comments?ive not had anything to do with these and would appreciate any advice or knowledge...thanxz in advance.
Jim in adelaide
peter_flane Offline
#2 Posted : Saturday, 18 April 2009 7:44:10 AM(UTC)
peter_flane
Typing 308 offset crank into Google search gave 885 results. Heaps of info there to start with, it seems heaps of people have comments there. Have a look and see if that helps.
#3 Posted : Saturday, 18 April 2009 7:58:00 AM(UTC)
Thanxz again Peter!!
Jim in adelaide
petaus Offline
#4 Posted : Saturday, 18 April 2009 8:11:05 AM(UTC)
petaus
are you talking about offset grinding to increase the stroke, they used to use small journal chev rods and get about 330 cu inch, this was befor stroker cranks became readly avaiable?
pete.
#5 Posted : Saturday, 18 April 2009 8:19:59 AM(UTC)
yeah i was,but been reading the google and dont think ill go that way..!thanxz thou!!
Jim in adelaide
bundybluedog Offline
#6 Posted : Saturday, 18 April 2009 6:31:13 PM(UTC)
bundybluedog
the width of the chev rod has to be changed aswell and you also use a chev piston but you have to make sure you find the right piston hieght as there are a few diferant types. when you find the right one you dummy asembel the engine find the average deck
greenhj Offline
#7 Posted : Saturday, 18 April 2009 7:06:17 PM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
too dear for what it is.
If you want to zing it to 9 grand, leave the stroke as is.
If you want more torque, the cheapest and easiest way is with a COME 3.48 crank, holden rods, acl piston.
Honestly, by the time you grind the standard crank, find
#8 Posted : Saturday, 18 April 2009 7:38:38 PM(UTC)
I Agree,after reading about it I dont like the idea of the offset crank,but as they say....different STROKES for different folks!..:)
Jim in adelaide
#9 Posted : Sunday, 19 April 2009 6:48:31 PM(UTC)
bundybluedog
its was going to cost me around $2000 for everything, crank grind, new rods new pistons, balancing and machining
#10 Posted : Sunday, 19 April 2009 7:25:13 PM(UTC)
Its not that much more for a 350 stroker kit from COME. I think all you need on top of that is the block machine work.
greenhj Offline
#11 Posted : Sunday, 19 April 2009 10:48:47 PM(UTC)
greenhj
This page was generated in 0.066 seconds.
