#1 Posted : Thursday, 30 April 2009 1:38:02 AM(UTC)
What is the earliest date you have seen a Holden panelvan with a full length headlining?
A small clue the HQ and the HJ Oct 74 parts books do not list a full length headlining.
#2 Posted : Thursday, 30 April 2009 4:45:04 AM(UTC)
Not sure. HJ from release are supposed to have it, and if you look in the 10/74 HJ Sandman brochure the van looks to have one (anyone got a scan of it that the can blow up and see better?).
#3 Posted : Thursday, 30 April 2009 5:31:53 AM(UTC)
I only have a 1/76 brochure and it has a red van with full headlining but we all know they were in well before this. The brochures sometimes lie though, the worst case of this was a HT brochure with a Chevrolet engine with a 253 decal on the air cleaner. I guess Holdens had not completed a 253 in time for the photo shoot.
Anyhow all HJs probably had a full length H/L but if anyone has an unmolestered, non re-bodied, original early HJ van it would be interesting to know for sure. Or did a couple sneak out the door?
Jvanner Offline
#4 Posted : Thursday, 30 April 2009 6:31:57 AM(UTC)
Jvanner
im the 3rd owner of a 3/75 kingswood van with some options. it has full hood lining.
adam PERTH Offline
#5 Posted : Thursday, 30 April 2009 7:09:24 AM(UTC)
adam PERTH
i spoke to another guy today with a jamacial lime HJ sandman with 18V trim.
ours both have white headlinings, which i thought it should have been black.???
WANTED:
-HZ GTS steering wheel, buckskin.
-2 x 15 x 8 Dragway centrelines
#6 Posted : Thursday, 30 April 2009 7:42:49 AM(UTC)
WANTED:
Holdens always had a neutral headlining option that in HJ would give you a Chamois headlining.
#7 Posted : Thursday, 30 April 2009 5:57:22 PM(UTC)
I wasnt aware that GM-H made an HJ Kingswood P/van. I thought the first Kingswood van was an HX (7/76 onwards).
Do you have photo a of the body or VIN plates.
Dr Terry.
classic oz wreck Offline
#8 Posted : Thursday, 30 April 2009 7:13:50 PM(UTC)
classic oz wreck
my hq sandman is black trim and had a neutral headlining...ive had a few heated conversations with supposed experts that it should be black but it was definately there from new...
www.classicozwreck.com.au
#9 Posted : Thursday, 30 April 2009 8:03:08 PM(UTC)
I have a HQ Sandman build sheet copy that shows neutral headlining. Oddly enough (and from memory) I think the option code for neutral headlining was XU3!
#10 Posted : Thursday, 30 April 2009 8:56:20 PM(UTC)
That is correct Byron, HQ series is XU3 for neutral H/L,
this changed on HJ-X-Z to XY9 for neutral H/L.
I guess the code is relevant to the colour as well, XY9 being Chamois and the XU3 would be Doeskin and/or Flax.
Edited by user Friday, 1 May 2009 12:27:35 AM(UTC)  | Reason: Not specified
cannon Offline
#11 Posted : Thursday, 30 April 2009 10:30:20 PM(UTC)
cannon
I have a completely stock unrestored HZ Sandman ute Slate black interior trim with off white head lining.
#12 Posted : Friday, 1 May 2009 3:54:07 AM(UTC)
Getting a little off track here , but trying make a little sense of it all , HK HT HG Panel Vans (although the short type )apparently all used Neutral Headlinings from new as mine has also . Although a few people claim they have seen coloured ones in HG ? And also the parts book does back this up , even though the parts book is not always 100% correct . But the HKTG utes all got colour coded ones as standard unless optioned with the neutral headlining ? Also many HT Prems particulary (other than antique gold) that i have owned all nearly were neutral headlining . I believe it was optional and many people ticked the box due to the heat factor rather than a black or the like coloured headlining. Just my thoughts .
www.monaromuscleparts.com
Edited by user Friday, 1 May 2009 8:28:26 AM(UTC)  | Reason: Not specified
#13 Posted : Sunday, 3 May 2009 4:36:24 PM(UTC)
[quote]Originally posted by adam PERTH
Can you tell me the dates on these vans please. Obviously original to still have the neutral headlinings still in them.
adam PERTH Offline
#14 Posted : Sunday, 3 May 2009 10:21:03 PM(UTC)
adam PERTH
mine is 9/75.
the other bloke didnt know what month his was.
but said it was 2200 kg, which means it was before 10/75.
Drew (SandmanXX7) might know, it was a margaret river van that he painted.
WANTED:
#15 Posted : Wednesday, 6 May 2009 2:47:59 AM(UTC)
mine is 9/75.
WANTED:
Thanks for that. By the way that buckskin wheel you want, Ebay 400046211876.
Mick50 Offline
#16 Posted : Wednesday, 6 May 2009 7:29:42 AM(UTC)
Mick50
I have a 5/76 Brisbane build Sandman van that I have owned from new.Paint is Mintjulip with 19v and it had neutral or chamois headlining originally.I hope this may help.
Guest (5)
This page was generated in 0.080 seconds.
