nhawtin Offline
#1 Posted : Saturday, 9 May 2009 5:20:29 PM(UTC)
nhawtin
does anyone know the correct lengths for the monaro saginaw tail shaft to ten bolt. i have a v 8 one but it seems to not be long enough but if i compare it to the shifter picture in the hk manual it looks correct. the yoke seems to sit way back. I think it might be for powerglide. So if someone has a speed ne that the want to swap no worries. thanks to all
#2 Posted : Saturday, 9 May 2009 6:05:12 PM(UTC)
Saginaw and Powerglide are the same tailsaft, for the same engine and diff. 53.71" is what Warren and Ben quote in the bible for the Chev, Saginaw/Powerglide with 10 bolt
nhawtin Offline
#3 Posted : Saturday, 9 May 2009 7:22:02 PM(UTC)
nhawtin
thank you. obviously measured from yoke centres???
nhawtin Offline
#4 Posted : Friday, 15 May 2009 7:38:35 AM(UTC)
nhawtin
is this measurement the centres of the yokes????
#5 Posted : Friday, 15 May 2009 6:12:23 PM(UTC)
I dont know, but Id assume so.
#6 Posted : Friday, 15 May 2009 6:33:36 PM(UTC)
Yes, the 53.71-inch measurement is from the centre of the front uni joint to the centre of the rear.
