bronsonHX Offline
#1 Posted : Thursday, 28 May 2009 8:50:03 AM(UTC)
bronsonHX
my hx has the fuel filler behind the number plate (im guessing standard for HX). when im filling it i have to go ridiculously slow or else i get a big bubble and fuel pouring out all over my hands. im thinking it is just the poor design of these tanks that causes it, but is there anyway i can stop this from happening? anything anyone has done or does to stop this from happening every time they fill up? it takes a solid 10 minutes to fill the tank.
308hjute Offline
#2 Posted : Thursday, 28 May 2009 3:49:12 PM(UTC)
308hjute
bronson,
I would be looking at dropping the tank and checking / renewing all the breather and emission hoses. A previous owner may have blocked one or more of them if they were perished. If you get under the car, with it securely on stands / ramps, you should be able to see the emission hoses at the front of the tank, behind the diff. There is a filler vent hose among these.
74HJLS Offline
#3 Posted : Thursday, 28 May 2009 7:09:12 PM(UTC)
74HJLS
I had that problem till I just pushed the nozzle in as far as it will go, right up to the plastic shield and no more problem.
Pete.
Pete.
petaus Offline
#4 Posted : Friday, 29 May 2009 9:15:08 AM(UTC)
petaus
i had a hx, never had that problem could fill up in like 2 minutes,as previous post get under tank and check all the pipes are in good nick and in correct spot.
pete.
toms-HZ Offline
#5 Posted : Friday, 29 May 2009 9:31:54 AM(UTC)
toms-HZ
I have no problem filling my HZ sedan but the wagon does take a while.
