basketcasebear Offline
#1 Posted : Thursday, 11 June 2009 2:04:00 AM(UTC)
basketcasebear
hey yall,
i am about to try to cut my own gasket for my quad carbee.
is there anything i should know, and or watch out for?
i am using a blank sheet of gasket paper, which is ok for oil? that what it says,
will this be hunky doory, for carbee gasket?
thanks already
bcb
it was but yesterday, i thought myself a fragment, quivering without rythum in the sphere of life.
now i know i am the sphere, and all of life quivers in rythmic fragments, within me!
kg.
DOH!!!
MrPink Offline
#2 Posted : Thursday, 11 June 2009 3:11:16 AM(UTC)
MrPink
BCB where are you going? Just buy one how much can they cost? Making your own gasket is when you are stuck the other side of the black stump and there is no other alternative.
#3 Posted : Thursday, 11 June 2009 4:00:38 AM(UTC)
basketcasebear
hey thanks mr pink,
but a new gasket costs 80 smakaroonies,, where as make my own is 5 smakers,, so as i am sure it is a leaking base gasket, just wanted to do this bit by bit,,
other wise it might end up having to have a full rebuild?
so was jest making sure it is okie dokie to use oil paper, an whether i should do anything else?
bcb
kg.
DOH!!!
Custom Offline
#4 Posted : Thursday, 11 June 2009 4:03:46 AM(UTC)
Custom
Make sure you use a "Kellogs" cornflake box and buy yourself a decent sharp knife!
Have you worked out how to use that multimeter yet.
HQforme Offline
#5 Posted : Thursday, 11 June 2009 4:07:33 AM(UTC)
HQforme
I agree that its handy stuff for those odd times when its needed, but gaskets are cheap and readily available, so 99% of the time i just have new stuff ready for the job im about to tackle.
If youre set on making gaskets, just use a good knife and be careful. Pay attention to the thickness of the gasket you took off as well.
"Silly modern cars"
bosko Offline
#6 Posted : Thursday, 11 June 2009 4:27:28 AM(UTC)
bosko
yeah itll be fine
if you dont have hole punches for bolt holes use an old socket + hammer, and if the socket is stuffed anyway grind a bit of an edge on it.
Browno Offline
#7 Posted : Thursday, 11 June 2009 6:01:37 AM(UTC)
Browno
yeah make the gasket its easy as, ive been stuck before and i have used cerial box carboard soaked in grease 4 where the fuel pump bolts on to the motor stil hasnt leaked ........
Drive It Like You Stole It......Drive it like you own it
#8 Posted : Thursday, 11 June 2009 6:15:38 AM(UTC)
basketcasebear
well thankee there all ewe,s fellas, i will have a go,
but can i use a coco pops box, instead of a cornflakes box???
taste is parormount, for such an undertaking,
bcb
kg.
DOH!!!
bosko Offline
#9 Posted : Thursday, 11 June 2009 6:19:05 AM(UTC)
bosko
get a roll of gasket paper
cocpops boxes are for when you are stranded
the shiny side doesnt seal as good as gasket paper
#10 Posted : Thursday, 11 June 2009 11:01:35 PM(UTC)
basketcasebear
well..!! hooley dooley,,
wait for this>>
took carbee off said veehikle,,found it had a ruelly thick, rubbery/plasticey,,bottom gasket..
found a small part of it had seperated, basically only a thin outer coating of itself and only between the 2 banks of holes, none too outside of carbee,,,, but no tears nor breaks in it anywhere.
decided to marry the new thin gasket, and sand wich the 2 together,
did this!! and WHOA!!! was missing and carrying on, and definately starved of fuel,
so i then took the new gasket off, and put it all back in with old gasket,, which is about 64/256th,s thick!
found engine not running very well still,
and then i noticed a pipe coming from the top back rim of carbee, going no where??
so i simply put a small amount of grease in end of pipe, and motor then was back the way it was before!!!! running i think rich??
does anybody know what this pipe coming from the back of carbee is for, and where it is meant to run too??
the only place i can see is a plate bolted into manifold next to base of carbee?
your help is thanked graciously, already,, [eddy]
bcb
kg.
DOH!!!
bosko Offline
#11 Posted : Thursday, 11 June 2009 11:50:23 PM(UTC)
bosko
goes to the charcoal can
sounds like your carb needs a proper rebuild
like that charcoal can vent has valves that tell the carb to vent to the can or the intake air and this will affect your vacuum signals
to tell if a carb is running rich or lean place your hand next to the air intake and slowly cover it up
if speed picks up its lean. if it drops its rich
but either way you need to rebuild at least the top part and then go from there
shanesmooth Offline
#12 Posted : Friday, 12 June 2009 3:28:42 AM(UTC)
shanesmooth
And you told me you wouldnt use your "car books" I gave you last BDAY bosko :P
#13 Posted : Friday, 12 June 2009 4:43:41 AM(UTC)
basketcasebear
hey bosko,
what charcoal can?? there is no charcoal can,? i presume you mean the round plastic canisters, that i used to have on another car?
this is a 308 in a 1998 ford transit, it will be going straight gas, so dosent matter re having a puefect carb,, but i do have to get it to the gas fitterer, that will mean a few k,s driving,, and was trying to get it running reasonably good untill then.
a mate pulled her apart, and he is an excellent mechanic, and he said the carb was ridgy didge.
so i think i have stuffed the base gasket up when i had to take it off, and this was causing the prob,
the choke has been tied off, and i am sure this little pipe was going into the top of the manifold?
anyways i will try checking tomorrow, see if it is actually is running rich,
thanks for thine input.
basketcasebeer
kg.
DOH!!!
The Yeti Offline
#14 Posted : Saturday, 13 June 2009 5:58:14 PM(UTC)
The Yeti
80 Smackers for a 4BBL base gasket? I think not thats about right for a small parts kit.
but if you are going to make one your self with gasket paper, being gentel with a small ball pein hammer and tapping on the sharp edges and it will come up perfectly
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yetis Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
See The Yeti's Chev build at
#15 Posted : Sunday, 14 June 2009 4:14:21 AM(UTC)
basketcasebear
well i ended up getting a proper thickness one from a mate,
and put her on,, there is a slight difference,, hard to pin point it.. certainly running, i think slightly leaner,,was certainly harder to start,
needs a guru to have a squiz,,
next week,
thanks to all ewes support, and will let ya all know how it all ends up.
bcb
kg.
DOH!!!
Guest (7)
