gmholdman Offline
#1 Posted : Thursday, 11 June 2009 7:11:35 PM(UTC)
gmholdman
Help needed, there was a topic posted with a new formula for working out a power to weight ratio . Apparently it is used in WA and soon to be used in Qld??? Example being a 454 could not be used in say a Torana. Anyone remember the post???? AL.
PISTOF Offline
#2 Posted : Friday, 12 June 2009 1:12:48 AM(UTC)
PISTOF
Who knows if, when, or what states these new NCOP laws will effect but this is them... engine laws on page 18.
http://www.infrastructur..._LA_Engines_3Feb2006.pdf
gmholdman Offline
#3 Posted : Friday, 12 June 2009 5:21:56 AM(UTC)
gmholdman
Thanks for that PISTOF, but has anything changed since that was printed in 3 Feb 06?? AL.
PISTOF Offline
#4 Posted : Friday, 12 June 2009 11:37:18 AM(UTC)
PISTOF
Al, im fairly certain those engine laws have only just been written. If they are old then there is a state that has been using those engine laws for years, anyway they are the laws that are being pushed to become national and as i said, who knows if, when, or who they will effect.
When the laws change they replace pages with new ones, they dont rewrite the whole book, hence the feb 06 on the first page. The new pages will be dated accordingly.
The old or current laws in QLD (if theyre still current) are:
4 cyl and rotary as biggest factory engine weighing under 1100kg... Naturally aspirated: Original weight in kgs x .183 = largest cubic inches. Blown or turbo: Original weight in kg x .153 = largest cubic inches.
All other MONO constructed 4s and rotaries over 1100kg aswell as all 6 cyl and 8 cyl: Naturally aspirated.. Original weight in kg x .294 = largest cubic inches. Blown or turbo: Original weight in kg x .244 = largest cubic inches.
4s and rotaries over 1100kg aswell as all 6 cyl and 8 cyl with SEPARATE chassis: Original weight in kg x .333 = largest cubic inches. Blown or turbo: Original weight in kg x .286 = largest cubic inches.
Hope that helps. If you find out whats happening with the new laws let us know. Cheers.
Edited by user Friday, 12 June 2009 11:53:30 AM(UTC)  | Reason: Not specified
gmholdman Offline
#5 Posted : Saturday, 13 June 2009 7:40:27 AM(UTC)
gmholdman
Touche.
