Can anyone tell me if you can change the outer gears in a banjo diff so you can use say coarse spline axles in an original fine spline diff ( 3.55 RATIO ) TO A COARSE SPLINE DIFF ( 2.78 RATIO )
Yes. Those sun gears are the difference between coarse and fine spline centres. Not sure how its done though as I have never done it myself. From memory you have to change the gear and the cone on each side too if its an LSD.
Thanks Just looking to pic one up for the sons Torana but having probs picking up a coarse spline to suit his axles
What model Torana? If its an LH/LX just use some fine spline axles. They are easy to find.
AFAIK most LX have fine spline axles, but wouldnt an HQ diff be more readily available. All 6-cyl HQs had coarse spline axles & they would be easier to find than Toranas.
Dr Terry. |
