hi just finish my v8 tonner and the speedo is not working right it is auto with a 3.08 diff what color drive am i to use can anyone help and would anyone have the right one i can buy at the right price thanks cheers allen
old fart racing the older i get the faster i was |
It depends upon the box, and where it came from.
thank for the help going buy the Speedo Gear Calculator i need a pink one to make it 99.9 o/o right so if any one can help out let me know thank cheers allan
That calculator may/will be wrong as not all gearboxes of the same type (eg trimatic) have the same drive gear. So you may need to know what the gearbox came from (by the code on the side for am auto).
Joined: 2/03/2005(UTC) Posts: 451  ![Australia Australia]() Was thanked: 15 time(s) in 14 post(s)
A large range of new speedo gears in the correct colours is available at Rare Spares. Check the shop online on this page top RH.SG4023 may be the part you are looking for.
the box is out wb / commy type left hand shift 3 speed auto does this mean what is tell me where i have gone wrong cheers allen
Get the code off the plate on the box. Unless its been rebuilt and the drive gear replaced itll be easy to get the right gear. I assume its a trimatc and not a TH350?
i reckon just stick the pink gear in and give it a go, the worst you can do is have your speedo out by a few ks, and if that bothers you then get the gear lower or higher
most auto shops sell them new still
If you are unable to get the speedo drive correct to have your speedo accurate, a ratio box can be fitted between your box & speedo cable. Once a test run is done over a set mile, the amount of revolutions that your current speedo drive gives is compaired to what your speedo head requires. A small ratio box is then calculated & built to rectify the difference. I have had this done a couple of times with great success. The box is smaller than a matchbox. Make sure that you are happy with your driveline setup prior to having this done. Tyre profile will change speedo accurracy. Contact is below. Ringwood Speedometer Service (03) 9874 2260 693 Whitehorse Rd Mitcham VIC 3132 Utility8  |
utility8
