Allan Offline
#1 Posted : Wednesday, 22 July 2009 6:12:09 AM(UTC)
Allan
Hi Guys,
Does anyone know of a sound deadening product other than Dynamat??
A $1000 for enough to do my car is ridiculous!
Surely their is a cheaper alternative?
Allan
Mr.Jones Offline
#2 Posted : Wednesday, 22 July 2009 6:55:08 AM(UTC)
Mr.Jones
I use carpet underlay and glue it up on the inside of the firewall, and also behind the back seat up the bulkhead. Cut out a lot of road noise pity about the crap seal on the windows. Mine also has that bitumen stuff underneath the car.
Leroy
"Planet earth is the asylum to which the rest of the universe sends its lunatics"
Voltaire
Voltaire
80569K Offline
#3 Posted : Friday, 24 July 2009 12:48:26 AM(UTC)
80569K
Try ebay, I got an unopened bulk pack of Dynamat extreme for $200 which was enough to do a HK sedan.
Or Google auto sound deadener, Fatmat is another one, there are plenty of brands out there.
I went for the aluminium backed bitumineous insulation because when its applied correctly it is pretty well waterproof. Underfelt on its own traps water between the floor and the carpet. I used Dynamat and a high quality underfelt and the result is terrific, really good sound & heat insulation.
vanman Offline
#4 Posted : Saturday, 25 July 2009 12:39:55 AM(UTC)
vanman
just bought 240 FT eDead 45 Sound Deadener
not sure how good it is but its cheep enough...checked a few forums and the response was positive.
from what i can figure there are three main types of sound deadener matting fiberglass, tar, and Butyl Rubber..
they seem to be rated in this order with the Butyl Rubber rated highest..
I have seen this on eBay au for $130 for 30ft
this is what i have coming in in the next container...
http://cgi.ebay.com.au/ws/eBayI...WNX:IT&item=200267403806
Mr Void Offline
#5 Posted : Monday, 27 July 2009 4:33:33 AM(UTC)
Mr Void
Allan, are you in Sydney?
___________________
Why are you reading this, you should be looking up there^^
___________________
Allan Offline
#6 Posted : Monday, 27 July 2009 5:44:04 AM(UTC)
Allan
Hi Guys,
No. I am in Rockhampton!
Have tracked down a product called Resomat from Tru-fit carpets which seems reasonable!
3.4 square metres of 2.7 mm Resomat with heat shield for $175.
Sounds good too me!
Ill let you know how it turns out.
Allan
