cs123 Offline
#1 Posted : Monday, 17 August 2009 6:38:22 PM(UTC)
cs123
Hey guys,
Doing an engine swap. Holden v8 in place of a 202 in a WB.
The new engine has what appears to be a fuel pressure relief valve in the fuel line near the carb.
I currently have it plumbed into the line used by the charcoal canister to return the fuel to the tank and have the canister disconnected.
How am I suppose to connect this? The car does not have a separate line and I want to use the canister for compliance with ADRs.
#2 Posted : Monday, 17 August 2009 6:46:50 PM(UTC)
Going from memory, the auto V8s ran an extra line from the tank to the engine, so your best bet would be to go and look at say a HX-WB Statesman and have a look at how the line is run and where it runs to, and copy it. If no-one else answers today ill have a look tonight and see if there is a picture of it in a parts catalogue.
hztonner Offline
#3 Posted : Monday, 17 August 2009 7:00:32 PM(UTC)
hztonner
hi if you want more info just call me as i have done many of these
(0428554013 ask allen)
old fart racing the older i get the faster i was
mackv8 Offline
#4 Posted : Monday, 17 August 2009 7:50:26 PM(UTC)
mackv8
i have only seen it on hz and wb factoy 308/5 litter v8 autos fitted with factor air con.
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
cs123 Offline
#5 Posted : Monday, 17 August 2009 8:50:56 PM(UTC)
cs123
That would explain it. I the donor was a WB statsman auto with air.
So can I replace this if I have a manual without air? Is the fuel pump different?
#6 Posted : Monday, 17 August 2009 11:00:35 PM(UTC)
Yes was nly on 308/350 auto with air. Fuel pump is the same
Replace fuel line, or use 253 in line filter.
Fuel pump same
Warren
Edited by user Monday, 17 August 2009 11:03:34 PM(UTC)  | Reason: Not specified
cs123 Offline
#7 Posted : Tuesday, 18 August 2009 1:16:07 AM(UTC)
cs123
Thanks everyone. Will remove it.
