nhawtin Offline
#1 Posted : Saturday, 22 August 2009 8:41:13 PM(UTC)
nhawtin
Hi guys after info again. Did the hk monaro stndard belmont ix have a painted grill(black) or open chrome.. Any images would be greatly appreciated. [email protected]
They didnt have gts hubcaps or six inch rims? I am trying to help a guy restore to orginal. thanking youin advance
80569K Offline
#2 Posted : Saturday, 22 August 2009 9:19:12 PM(UTC)
80569K
From memory the base HK Monaro had a standard no paint grille, standard HK 5" rims and the GTS wheel covers were optional on all HKs.
Grue Pugg Offline
#3 Posted : Saturday, 22 August 2009 10:02:05 PM(UTC)
Grue Pugg
whats a hk monaro standard belmont ix?
the base monaro was based on a kingswood, grill had middle 2 bars top and bottom unpainted, rest of bars black. Top and bottom unpainted. unpainted is anodise not chrome
belmont sedan/ute/van/wagon had all bars unpainted but they were still blacked behind the chrome centre bar and on all the vertical bars and behind the Holden badge
Edited by user Saturday, 22 August 2009 10:58:00 PM(UTC)  | Reason: Not specified
80569K Offline
#4 Posted : Saturday, 22 August 2009 10:26:37 PM(UTC)
80569K
Thankyou GP, my memory did not serve me correctly.
#5 Posted : Sunday, 23 August 2009 2:15:56 AM(UTC)
There are some NOS side trims for a HK 337 on Ebay at the moment, for the rear quarter between the wheel and the door. Id probably have the equivalent for the doors, but maybe not NOS, possibly also those for the rear of the quarters.
nhawtin Offline
#6 Posted : Sunday, 23 August 2009 10:03:13 PM(UTC)
nhawtin
OK does anyone have images of these please. NExt comment is it has had a GTS heater box (grey) and a gts wheel fitted. would you say it was optoned or fited from a wreck at later date.
#7 Posted : Monday, 24 August 2009 1:36:20 AM(UTC)
Being a 2 door Kingswood it had many options, so yes the heater (C42) could be optioned. The GTS wheel could not though.
Here is a list of options that could be fitted during production. Those with a * could also be fitted in the dealership as an accessory.
Option Description
A02 Tinted windscreen glass
A22 Laminated windscreen glass
A62 Delete front seat belts (export)
A64* Rear lap belts
A68* Centre rear lap belt
AL7* Protective screen
B21 Door pull to handle 1 door
B26* Door pull handle both doors
B30 Floor carpets
B34 Heavy duty front floor mats
B35 Heavy duty rear floor mats
C08 Exterior soft trim roof covering (off white)
C15 Delete windscreen washer
C27 Exterior soft vinyl roof cover (black)
C40* Outside air heater and demister
C42 De luxe heater with fan
C64 Air conditioning
D17 Rear quarter armrests
D18 Assist grip handles
D31 Antiglare rear vision mirror
D44 External rear vision mirror passenger side fender mount
D94 Touch up paint
DD1* Windscreen exterior sunshade
F38* Front crossmember protection plate
F60 Heavy duty front springs
G50 Heavy duty rear springs
G66* Supper lift shock absorbers
G80* Limited slip differential (mandatory with L30)
G88 3.36 Salisbury limited slip rear axle
G89 3.35 Salisbury limited slip rear axle (not with C64)
G90 3.90 Banjo rear axle
G91 3.55 Banjo rear axle S
G92 2.78 Banjo limited slip rear axle (only with L30)
G93 3.08 Banjo rear axle
G94 3.08 Salisbury limited slip rear axle
G95 3.36 Banjo rear axle
J50* Power brakes
J52 Front disc brakes
K45* Heavy duty air cleaner (not with L30 or L66)
K69 Ignition key (3 key set)
L20 186 HC engine
L30 5 litre V8 HP engine
L61 Economy carburetor (not with L22, L30, L66, C64)
L66 186S engine
M11 Floor shift console (only with M35 and mand. with M20, M21)
M15 Manual transmission 3 speed full synchronized
M20 Manual transmission 4 speed
M21 Manual transmission 4 speed heavy duty 2.54:1 1st
M35 Powerglide transmission
MA1 Magnetic chip collector (not with M20 or M35, part of M21)
N05* Locking fuel cap
NA2 Fuel tank captive filler cap
NA3 Fuel pipe anti theft spring
NA4* Fuel tank stone guard
N40* Power steering
N44 Fast ratio steering
N61 Delete spare wheel (only with P32)
N66 Wheel rally type 6.00JJ x 14
N84 Tyre band red
N91 Wheel trim disc
N99 Heavy duty wheels
P26 Tyre band white
P32 Delete spare tyre
P50 Tyre 185 x 14 radial
P51 Tyre and tube Michelin 185 x 14 radial XAS
P52 Tyre Pirelli 185 x 14 radial
P53 Tyre and tube Michelin 175 x 14 radial X
P57 Tyre 7.35 x 14 4 P/R (STD L) (not with N84 or XT1)
P69 Tyre 6.95 x 14 4 P/R (Premium S) (not with XT1)
P70 Tyre 7.35 x 14 4P/R (Premium) (not with XT1)
P73 Tyre 7.35 x 14 6P/R (not with P26, P84 or XT1)
PP9 Tubeless tyre 6.95 x 14 6P/R (not with P26 , N84 or XT1)
PX4 Tyre D70 x 14 4P/R (high performance H) (only with N66)
T47* Hood ornament
T57* Front fender mud deflector
T60 Heavy duty battery (61 AH dry charge)
T64 Delete battery
T75 Amber headlamps (export only)
T85 Amber backup lamps (light switch controlled, Government only)
T89 Tail and stop lamp assembly (export)
T95 Inspection lamp (government only)
TN1 Heavy duty battery (53 AH dry charge)
TP1 Heavy duty battery (53AH wet charge)(std with L30 and/or C64)
U05* High note horn
U16 Engine tachometer (only with M11, not with C64)
U18 Kilometer speedometer (export only)
U27* Instrument compartment lamp
U40* Park brake warning lamp
U46* Monitor stop lamp (government only) X
U50 Radio interference suppression(not with U60, U61, U63 or U52)
U52 Radio interference suppression VHF (not with U60, U61, U63 or U50)
U60* Manual radio 11 transistor
U61* Manual radio 6 transistor
U63* Push button radio 11transistor
U80* Rear seat speaker (only with U60, U61, U63 radios)
U98 General purpose outlet (government only)
UA1 Heavy duty battery (61 AH wet charge)
UA5 Clamp type battery terminals (Not with L30)
UC2 Cluster assembly British units
UC3 Cluster assembly metric units (export only)
V01 Heavy duty radiator
V75 Underbody proof coating
V85 Fire extinguisher (handle type Pyrene)
V86 Fire extinguisher Graviner BCF 2lb
XS3 Mandatory additions and deletions (export only)
XS6 Bucket seats reclining
XT1 Tube equipment (only with P50, standard with P51, P53)
XT4 Tinted windscreen glass
Warren
Edited by user Monday, 24 August 2009 1:38:17 AM(UTC)  | Reason: Not specified
Grue Pugg Offline
#8 Posted : Monday, 24 August 2009 2:49:12 AM(UTC)
Grue Pugg
what does T95 look like, is it fixed to underside of bonnet?
is U27 glovebox light?
what is U98?
what does T85 look like? additional rear lamps? mounted where?
whats NA2? a chain?
Grue Pugg Offline
#9 Posted : Monday, 24 August 2009 3:03:31 AM(UTC)
Grue Pugg
oh noes, i bet T95 is like a mini sized trouble light that uses a 12v globe and has a rather long lead. which means I chucked one out that came with a 186S hk kingswood, and that car also had what must be U46 - a light with STOP written on it mounted under the dash. maybe was a govt car then. 186S/4sp opel and console
what is K69? just an extra key or?
#10 Posted : Monday, 24 August 2009 5:26:43 PM(UTC)
Yes the car you wrecked would have been a Government car with those options.
Not sure what a lot of these look like, but yes Monaros were ordered by departments. Have recently found a GTS 350 painted in NSW Ambulance Beige from the factory, suggesting someone in the NSW ambulance service liked the GTS 350 and ordered one for his/her company car.
Warren
#11 Posted : Monday, 24 August 2009 6:59:44 PM(UTC)
Hi Warren.
What is the difference between AO2 & XT4 ?
#12 Posted : Monday, 24 August 2009 7:23:59 PM(UTC)
one will be laminated and tinted.
Warren
#13 Posted : Monday, 24 August 2009 7:56:02 PM(UTC)
Warren
You might also want to add L34 to your list of options. I know it wasnt a mainstream option but some examples were built.
#14 Posted : Monday, 24 August 2009 10:39:50 PM(UTC)
Byron, I only listed options for Monaro (0337) not all Monaro options (0737 and 1837), note no delete stripes.
If I was to add the L34 then would also need to add the radius rods and 25 gallon tank option codes.
Warren
Edited by user Monday, 24 August 2009 10:40:30 PM(UTC)  | Reason: Not specified
#15 Posted : Tuesday, 25 August 2009 12:34:26 AM(UTC)
OK, understand now, although can you be certain that no L34 optioned 337 was built? (nit picking I know, just really good, interesting discussion).
Also, what option code was the boot ornament (that looks like a grille badge sideways)? Ive seen these on an original 337 before. It was a fully loaded car. 307, air, steer, venetian, GTS wheel trims, etc etc. I think it even had the canvas water bottle support on the front bar. It was an extremely early Mako blue car with 14X trim, special order for a dealers floor.
Terry, XT4 will probably be tinted armourplate. Axx series are laminated.
#16 Posted : Tuesday, 25 August 2009 1:08:05 AM(UTC)
I think things like boot ornaments, water bag holders, weathershields & venetians etc. were available only as dealer accessories & not as factory options. Therefore they had no P.O. number.
Good point about the glass, although I did see one listing which had AO1 for tinted armourplate windscreen & AO2 for a tinted laminated screen. It probably varies with model.
Grue Pugg Offline
#17 Posted : Tuesday, 25 August 2009 1:22:09 AM(UTC)
Grue Pugg
what is option L34
#18 Posted : Tuesday, 25 August 2009 1:47:08 AM(UTC)
327. Originally the "Bathurst" Monaro was meant to be option L34 on a 737 (like XU-1 on GTR, L34/A9X on SLR, XW8 on HQ 469 etc), but was made a separate model, from what ive heard to "hide" it from GM US. However like in HQ with the 350 sneaking into cars it shouldnt be in (ute, Premier, Kingswood etc) in HK the same thing probably happened. So possibly there might have been an L34 optioned 337. Oddly enough, I think my #2 Pagewood HK 1837 may have started in the planning stages as a 737 as the VIN plate has the PSN stamped normally, but the 81837K bit stamped with the top down stamps, but looks to be stamped over an original stamping. The BODY plate is normal and says 81837KR-00002-H5. It might have been a mistake too, but further information Ive heard recently makes me think otherwise.
#19 Posted : Tuesday, 25 August 2009 2:44:22 AM(UTC)
The L34 option disappeared well before the first production cars started down the line, at least one protoype was built under L34, but this car would have been sent to Lang Lang for evaluation.
Would an 0337 be fitted wih an L34? good question, maybe one may have been, but there were many other options that were not for Monaro such as XS9, now a car on special order may have recieved this, but it was not a normally available option so I did not list it.
If I was a betting man I would put money on no 0337/0437 being fitted with a 327/350 engine, yes in the HQ some sedans and wagons got the 350, but no 0437 ever got it. Why would GM-H allow the exclusive high performance engine in a lower spec car of the same body? (I doubt any XU1 engines were ever fitted to S and SL Toranas either, or L34 308 engine fitted to an S or SL, even though physically possible)
As for the stamping, it is common for errors, especially when you consider that up until the monaro release all HKs started 80 and all Toranas started 82, so quite easy to see first Brougham or GTS 327 through the type writter, may have got 80 out of habit.
This is true of Brisbane cars, the early ones have 80837 on their VIN.
Early Melbourne cars have 80837 on their body plates, but the 0 is over stamped with a 1.
So are you saying early Sydney ars are the same as early Melbourne cars? If so it looks like the only typist doing their job was Adelaide.
Yes Greg U27 is glovebox light
#20 Posted : Tuesday, 25 August 2009 3:37:11 AM(UTC)
Its not just a 0 overstamped with 1 Warren, its the whole 81837K bit, followed by a normal H5xxxxx. Just looked again and it does appear that the bit before H5 was never stamped, so ive recently begun to wonder if when the VIN plate PSN was stamped (at Fishermans bend?) 81837 hadnt yet been allocated??
This page was generated in 0.120 seconds.
