JOSH UC SUNNY Offline
#1 Posted : Wednesday, 26 August 2009 11:09:08 PM(UTC)
JOSH UC SUNNY
I AM IN THE PROCESS OF FITTING A 2.8LITRE HOLDEN RED 6 TO THE UC TORANA AND AM IN A BIT OF A BIND AS TO WHAT DIFF RATIO I SHOULD USE. M20 GEARBOX, SALISBURY DIFF, TYRES ARE 205/60/13 IM AFTER REASONABLE ECONOMY AS IT WILL BE USED TO CRUISE ON THE HIGHWAY ABOUT 50% OF THE TIME. ANY INPUT WOULD BE ACCEPTED.
crowe Offline
#2 Posted : Thursday, 27 August 2009 2:28:41 AM(UTC)
crowe
3.08 ratio will do fine
#3 Posted : Thursday, 27 August 2009 2:34:17 AM(UTC)
If the motor is stock a 3.08 will work well. If the motor is modified you may need to go to a 3.36 to keep it drivable.
Mr Void Offline
#4 Posted : Thursday, 27 August 2009 8:32:24 AM(UTC)
Mr Void
3.36 is getting to be a rare ratio but now that I have them in my ute I would never complain about any economy issues. If you can find them Id say go for it!
___________________
Why are you reading this, you should be looking up there^^
___________________
This page was generated in 0.022 seconds.
