bathurst72 Offline
#1 Posted : Friday, 4 September 2009 10:05:05 PM(UTC)
bathurst72
Hi, I am after any info or contact numbers of a person that can tell me how much I can remove from the oil returm holes next to the lifters in a 202.The holes are about 13mm and I think they may go out to 14.5mm.
I have increased the oil returns in the cylinder head but after info on the above.
any info appreciated
Steve [email protected] or 0427197267
Mr Void Offline
#2 Posted : Saturday, 5 September 2009 3:05:39 AM(UTC)
Mr Void
Steve - it might be worth contacting redvk if no one replies. He has done a fair bit of oil channel work in his turbo 202. I think the contact website is in his build thread in the Members Rides section to.
___________________
Why are you reading this, you should be looking up there^^
___________________
#3 Posted : Saturday, 5 September 2009 3:31:30 AM(UTC)
hi mate, check out here http://holdenpaedia.oldh...on_Caused_by_Core_Shift:
some usefull info, dunno if its what your after but a interesting read anyway
#4 Posted : Saturday, 5 September 2009 3:52:34 AM(UTC)
Also Ask Peter smol or Commodorenut,they got it all worked out with these.
Jim in adelaide
peter_flane Offline
#5 Posted : Saturday, 5 September 2009 6:10:43 AM(UTC)
peter_flane
I dont have larger oil return holes in my 202. I dont have a high volume oil pump. I dont rev over 6000, so none of that would be necessary for my motor
http://www.ehlimo.com.au/
#6 Posted : Saturday, 5 September 2009 6:46:41 AM(UTC)
Peter , I didnt mean that you had it done,I meant you might have some advice,maybe.
Jim in adelaide
peter_flane Offline
#7 Posted : Saturday, 5 September 2009 6:56:36 AM(UTC)
peter_flane
All cool. My only advice is that if you are not using a high volume oil pump or revving it real high, then it would not be neccessary
bathurst72 Offline
#8 Posted : Saturday, 5 September 2009 8:41:13 PM(UTC)
bathurst72
Hi, I have a JP HV pump and the motor is going to be a Turbo with a good 300 hp.
steve
