#1 Posted : Thursday, 24 February 2005 2:30:48 AM(UTC)
Just wanted to know which chassis and bodies are interchangeable between HQ to HZ Holdens? Cheers
#2 Posted : Thursday, 24 February 2005 3:26:06 AM(UTC)
They're all interchangeable, even WB. The only things that stops you doing it easily are:
ADR27A on HX, HZ and early WB (worse in later WB).
One bumper bar bolt on each side if HQ-HZ nose used on WB chassis and vice versa.
Mid HZ onwards rails
#3 Posted : Thursday, 24 February 2005 3:35:17 AM(UTC)
the front chassis rails on sedans wagons and satesmans are all interchangeable with each other (WB is slightly shorter at the front i think)
utes and panelvans have the same chassis and is interchangeable with all model utes and vans
tonner chassi
