laurence Offline
#1 Posted : Monday, 5 October 2009 8:34:53 PM(UTC)
laurence
Anyond had problems with electric current causing alloy radiater to suffer from electrolyze engine is ls2 and every thing is new rad back to auto have heaps of earths but have smallcurrent thru radiater ideas please
#2 Posted : Tuesday, 6 October 2009 6:59:33 AM(UTC)
if you worried about corosion then put a small block of zinc in the radiator
petaus Offline
#3 Posted : Tuesday, 6 October 2009 10:26:51 AM(UTC)
petaus
every car has some current passing through the cooling sysytem.
noramly under .3 of a volt you wont have a problem.
the coolant picks up traces of iron and other metals this gives a new earth,so it is important to change your coolant and keep it at the right concentration.
hope this eaxplains it a bit better. pete.
WBEN Offline
#4 Posted : Wednesday, 7 October 2009 7:50:02 PM(UTC)
WBEN
how would you test the current going through?
petaus Offline
#5 Posted : Thursday, 8 October 2009 8:39:36 AM(UTC)
petaus
get a multimeter on 20 volts setting or similar, one lead on the negative battery terminal and the other in the coolant carefully not to touch the core,this will give you a reading,try it on few different cars and you will see differnt readings.
pete.
Tour Director Offline
#6 Posted : Thursday, 8 October 2009 9:19:17 AM(UTC)
Tour Director
One problem is that the entire cooling system can carry current from any number of points in the vehicle. You also have a range of different metals throughout that conflict with each other.All of these contribute to the radiator being eaten away. In some models it is greater than others.Someone like ADRAD could advise you how to resolve it or at least how to reduce the corrosion. Its not only the coolant that comes into play but it certainly helps having it right.
laurence Offline
#7 Posted : Thursday, 8 October 2009 10:09:51 PM(UTC)
laurence
OK after flushing radiater several times trying two different tanks of rainwater then town water PH testing water rang guy in bribane who sells Voltage sponges they are a black box that conects to battery and up to 5 componants plus flush and treatment for coolent.He says this is a comman problem with cars more so new cars.Company is called interject it is world wide so I give it a try let you know how it goes
