Keeo Offline
#1 Posted : Wednesday, 4 November 2009 6:57:44 AM(UTC)
Keeo
The time has come to remove the hks speedo .The needle has dropped an dissapeared.Can they be repaired easily ,if so where and who ?Or would it be easier and cheeper to find anthor one? Plus are there any pitfalls apart from being fragile .regards keeo
#2 Posted : Wednesday, 4 November 2009 7:09:05 AM(UTC)
If you put too much pressure on the movement it will go out of callibration.
Warren
80569K Offline
#3 Posted : Wednesday, 4 November 2009 9:00:24 AM(UTC)
80569K
If you are talking standard 120mph speedo they come up on ebay and usually go pretty cheap. There are two brands and they are interchangeable (some early HKs had Flexdrive brand, the rest VDO). The GTS 140mph speedo cluster usually attracts a much higher price. If you live in the Illawarra area there is an instrument repairer at Unanderra, I got him to overhaul my HK gauges and speedo.
Keeo Offline
#4 Posted : Thursday, 5 November 2009 3:06:59 AM(UTC)
Keeo
Ok so if i get a 120mph speedo will the guts of it work in a 140 mph speedo,is it just the face thats different? The broken one is gts 140mph and the VDO brand i am on the mid north coast nsw
Keeo
80569K Offline
#5 Posted : Thursday, 5 November 2009 8:13:55 AM(UTC)
80569K
Just checking the HK parts catalogue and it looks like the 140mph speedo part of the cluster came as an assembly (ie, the "guts" is part of the speedo assembly) and it has its own part number which covers all engine types in the GTS. So if the speedo head is cactus then youd be looking for another one or a repair.
Keeo Offline
#6 Posted : Friday, 6 November 2009 3:59:16 AM(UTC)
Keeo
Thanks for the speedo information fellas,-keeo
