Mnbvcxz123 Offline
#1 Posted : Sunday, 13 December 2009 4:00:54 AM(UTC)
Mnbvcxz123
Probally asked before but will HQ disc brake stubs bolt up to a HT/HG subframe.
Utility8 Offline
#2 Posted : Sunday, 13 December 2009 4:04:37 AM(UTC)
Utility8
Certainly will.
Utility8
utility8
#3 Posted : Sunday, 13 December 2009 7:42:01 AM(UTC)
As above. They are the same thing, just swap left to right.
peter_flane Offline
#4 Posted : Monday, 14 December 2009 3:00:30 AM(UTC)
peter_flane
Is there a stub axle height difference HK HT HG HQ 1TONNER ?
#5 Posted : Monday, 14 December 2009 3:20:07 AM(UTC)
no the only difference is the tonner stubs are heat treated, just like the A9X toranas
#6 Posted : Monday, 14 December 2009 4:11:10 AM(UTC)
Agree, all the same. GMH used 1-tonner disc brake stubs on L34 and A9X. Peter, the different height stubs are the rest of the LH-UC stubs.
Mnbvcxz123 Offline
#7 Posted : Monday, 14 December 2009 4:30:19 AM(UTC)
Mnbvcxz123
Thanks guys and are these available new or does anyone know of a place where good second hand rotors, brakes and the stubs could be purchased.
peter_flane Offline
#8 Posted : Monday, 14 December 2009 4:51:16 AM(UTC)
peter_flane
LH UC would have different caliper mount yeah?
LH UC would have different KPI angle?
#9 Posted : Monday, 14 December 2009 6:29:12 AM(UTC)
pete, i remember reading about this a while ago so i did a search and found this http://oldholden.com/?q=node/45834/
hope this helps you out
#10 Posted : Monday, 14 December 2009 8:19:01 AM(UTC)
Caliper mount is the same, but the postion relative to the stub is different. KPI is also different as you suspect.
