Probally asked before but will HQ disc brake stubs bolt up to a HT/HG subframe.
Certainly will. Utility8  |
utility8
As above. They are the same thing, just swap left to right.
Is there a stub axle height difference HK HT HG HQ 1TONNER ? If it is old or rare - Cut it! http://www.ehlimo.com.au/ |
no the only difference is the tonner stubs are heat treated, just like the A9X toranas
Agree, all the same. GMH used 1-tonner disc brake stubs on L34 and A9X. Peter, the different height stubs are the rest of the LH-UC stubs.
Thanks guys and are these available new or does anyone know of a place where good second hand rotors, brakes and the stubs could be purchased.
LH UC would have different caliper mount yeah? LH UC would have different KPI angle? If it is old or rare - Cut it! http://www.ehlimo.com.au/ |
pete, i remember reading about this a while ago so i did a search and found this http://oldholden.com/?q=node/45834/hope this helps you out
Caliper mount is the same, but the postion relative to the stub is different. KPI is also different as you suspect.
