toddyg Offline
#1 Posted : Monday, 14 December 2009 3:58:30 AM(UTC)
toddyg
hi,have a weeping oil leak at shift linkage on powerglide,would this seal be easy to replace,or is it a job for auto shop.
Keeo Offline
#2 Posted : Tuesday, 15 December 2009 8:27:29 AM(UTC)
Keeo
This might be a job for someone whos replaced a (throttle valve control sharft oil seal) before. Unless you have a powerglide repair manual,the one ive got looks like you have to remove the vavle body to get at it properly.I may be wrong but it could be a big job.How bad is the leak ?A wipe over every weekend maybe all you need.cheers--keeo
#3 Posted : Wednesday, 16 December 2009 2:58:45 AM(UTC)
If in doubt pull the shifter arm off the side of the transmission and see if there is an O ring there. If there is and it looks easy to replace just replace it.
If it looks more difficult than that I might win the blue and white striped apron award for this but measure the diameter of the shifter shaft, buy an appropriate sized neoprene O ring, slide it onto the shaft and bolt the linkage back on.
It should stop the leak for a couple of years at least. Hmm how do I know that 8-)
If at first you dont succeed then skydiving is not for you.
80569K Offline
#4 Posted : Wednesday, 16 December 2009 3:39:19 AM(UTC)
80569K
I guess we are assuming that you have checked the modulator and speedo drive for leaks.
#5 Posted : Wednesday, 16 December 2009 4:36:33 AM(UTC)
Jim, this wont work on a Powerglide transmission. Both the shifter & kickdown levers which connect to concentric tubes thru the same hole are welded on. You have to pull the valve body the then disconnect & remove the levers etc. & then replace the seal & O-ring.
There are only 3 types of people in the world.
1. Those who make things happen.
2. Those who watch things happen.
3. Those who wonder what happened.
#6 Posted : Wednesday, 16 December 2009 6:12:17 AM(UTC)
Pull it out ,It will leak somewhere else soon anyway.
toddyg Offline
#7 Posted : Wednesday, 16 December 2009 7:39:53 AM(UTC)
toddyg
thanks everyone for replying,will check out what jim replied.
petaus Offline
#8 Posted : Thursday, 17 December 2009 8:20:50 AM(UTC)
petaus
how abouta bottle of wynns stop leak???? lol
Guest (5)
