#1 Posted : Tuesday, 5 January 2010 9:02:26 PM(UTC)
Question 1 :can you paint acrylic on the top of 2 pak?If you can how?
question 2 :can you paint 2 pak onto acrylic and how?
The reason Im asking is that I have 4 liters of metallic silver 2 pak and I might spray the inside of the back of my van,but I am worried about chemical (or any)reaction etc....any help,I could just reverse tape the line,but just want to know about it.
peter_flane Offline
#2 Posted : Wednesday, 6 January 2010 5:01:50 AM(UTC)
peter_flane
You can do both methods, however it is like bogging a panel 1 inch thick. Not the right way, but looks ok. Would you put an inch of bog in a panel?
#3 Posted : Wednesday, 6 January 2010 5:22:34 AM(UTC)
jim, spraying 2 pac is toxic, it can be dangourous even in a spray booth, if you do this then make sure you use heaps of protective clothing EXPECIALLY breathing equiptment
AMunro327 Offline
#4 Posted : Wednesday, 6 January 2010 5:38:21 AM(UTC)
AMunro327
Jim, my car is acrylic on the panels and 2 pack on the openings. At the junction where they meet, they flare. Use Isolator at the jusction and they dont flare.
Bob
#5 Posted : Wednesday, 6 January 2010 6:04:54 AM(UTC)
A few more questions...NO!..to the 1 inch of bog,...yep I know its toxic but thank you Dave for the warning I might not have known(seriously)!
.Its ONLY going in the back(van area)not going outside at all....What is flare/flaring?.Would running masking tape fix this at the back?.I am only doing the inside of the back the rest is going to be acyrlic.
#6 Posted : Wednesday, 6 January 2010 6:07:09 AM(UTC)
once again, a simple, easy question made complicated, and i havent even sais anything yet..
I innovate, never imitate..
peter_flane Offline
#7 Posted : Wednesday, 6 January 2010 6:17:39 AM(UTC)
peter_flane
Well there are a number of answers to the questions at hand. Too many variables are unknown.
Simply, Yes you can use the Metallic silver basecoat in the back of your van, and using all the manufacturers recommended primer and preparation, and reducer, and paint application method, clearcoat and dry times, then it should work well. Then paint the outside of the van in acrylic lacquer using all manufacturers recommended products and it should come up well also. The junction between the two paints should be fine if prepared using the manufacturers recommended procedure. If they do not recommend it, then thumbs up if it works.
#8 Posted : Wednesday, 6 January 2010 6:30:50 AM(UTC)
Thank you all.
#9 Posted : Wednesday, 6 January 2010 6:40:22 AM(UTC)
i love you jim xox
#10 Posted : Wednesday, 6 January 2010 6:41:17 AM(UTC)
and pete smol is ace as well xox
#11 Posted : Wednesday, 6 January 2010 6:42:53 AM(UTC)
righto frank, put it back in ya pants
howd ya like the shell thread on the other site, lol
#12 Posted : Wednesday, 6 January 2010 6:47:58 AM(UTC)
lol, which one davey???
#13 Posted : Wednesday, 6 January 2010 6:52:25 AM(UTC)
this one http://oldholden.com/node/79608 all i did was give the guy another option and it took off, lol, 81 post later there still going, hahahaha
#14 Posted : Wednesday, 6 January 2010 6:59:36 AM(UTC)
oooooooooooohh yeah......amazing stuff..i love it..lol theses dudes get all to serious sometimes. i might have to join that site i think...
#15 Posted : Wednesday, 6 January 2010 7:19:09 AM(UTC)
haha, yeah thatd be a larf, lol
