Biga064 Offline
#1 Posted : Sunday, 17 January 2010 9:25:40 PM(UTC)
Biga064
Hi how much do you shim or space the spring to raise oil pressure on a 6 cyl holden oil pump ? Have shimmed it about 8mm for 40psi at around 4500 revs . Does 8mm sound to much ? or not enough ? Thanks for any help .
adam PERTH Offline
#2 Posted : Monday, 18 January 2010 9:18:42 AM(UTC)
adam PERTH
Ellerys cover this in the engine section.
40 psi wont be enough for 4500 rpm.
aim for around 60 psi.
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
This page was generated in 0.111 seconds.
