Absinth Offline
#1 Posted : Friday, 22 January 2010 10:22:41 PM(UTC)
Absinth
Les, have Rares thought about reproducing the front half of the GTS speedo and tacho cases. The rear white section is usually good but the front blacked out part of the housing 80% of the time has broken mounting lugs.
The part No. MNF-148 at the top of the housing is the same part used on the speedo and the tacho on HJ, HX and HZ. I have six HJ, HX GTS dashes and out of the twelve housings nine of them have broken or cracked mounting lugs.
I had a Tacho years ago that all the lugs had broken off, I had to glue metal tabs to the housing so I could screw it in place to stop it rattling around in the dash.
Tour Director Offline
#2 Posted : Saturday, 23 January 2010 3:00:48 AM(UTC)
Tour Director
Those numbers refer to the actual manufacturer for identification means.As there were two companies Flexdrive & VDO that made gauges you have to check which one made the parts.Usually this is moulded into the rear part.
les Offline
#3 Posted : Saturday, 23 January 2010 3:28:08 AM(UTC)
les
Absinth
Let me do some investigation on them to see if they are viable
Les
Absinth Offline
#4 Posted : Saturday, 23 January 2010 3:30:19 AM(UTC)
Absinth
That only applies up to HQ.... from HJ onwards all GTS instruments were Flexdrive, in fact I dont ever recall seeing any VDO instruments in HX onwards, not sure about the HJ strip speedo. Just as a side note I have never seen a HQ GTS speedo or Tacho that wasnt made by Flexdrive either.
You are right about the MNF number though, I just checked some standard HX and HZ speedos and they have the same number.
The GTS speedo and tacho housings are unique and differ from the standard housings so you cant swap them over for better ones from a standard speedo.
HZute-efi-VS5L Offline
#5 Posted : Saturday, 23 January 2010 7:10:18 AM(UTC)
HZute-efi-VS5L
I would agree over half the gts dashes I have the tacho and speedo have atleast one broken lug.
www.stickthisdecals.com.au
les Offline
#6 Posted : Wednesday, 27 January 2010 5:39:49 AM(UTC)
les
Is this front part the same for Speedo & tacho in all GTS models from HJ- HZ
#7 Posted : Wednesday, 27 January 2010 5:54:52 PM(UTC)
HZute-efi-VS5L
yes exactly Les
les Offline
#8 Posted : Thursday, 28 January 2010 5:57:38 AM(UTC)
les
Ok it looks like a goer we will eventually make the whole gauge this could be a good start.
#9 Posted : Friday, 29 January 2010 5:24:33 AM(UTC)
HZute-efi-VS5L
Sounds good Les. I dont know if the whole gage is needed. Good speedo repair companies can fix them no worries. Not sure there would be a market for them.
The surrounds etc are defiantly worth while. Maybe also the needle as these as sometimes broken. To be honest even on a very old damaged gauge the speedo face with the markings etc is nearly always in good condition. Sometimes may need new white or red on them but this is easily done.
If a new speedo is say going to cost $150 than Myself i would prefer to get an original recond. Replace the lens and housing and get it calibrated.
Jason
Absinth Offline
#10 Posted : Sunday, 20 March 2011 10:53:05 AM(UTC)
Absinth
Any news on these housings being made?
les Offline
#11 Posted : Wednesday, 23 March 2011 2:04:06 AM(UTC)
les
We have rejected the latest sample , but they are close to being correct. They are about 3-4 months away
Guest (11)
This page was generated in 0.066 seconds.
