grse.mnky85 Offline
#1 Posted : Monday, 25 January 2010 8:19:49 AM(UTC)
grse.mnky85
i have a 99 vt wagon have put 2 1/2 inch exhaust with high flow muffler in back pull up at set of lights car coghs and splutters even on take off i have code 29 come up EGR sensor position fault. some people say replace egr some say it something else i need help....
ozchevy Offline
#2 Posted : Monday, 25 January 2010 8:27:42 AM(UTC)
ozchevy
Not my field of expertise, but Id be looking at the O2 sensor
#3 Posted : Monday, 25 January 2010 8:48:11 AM(UTC)
plug it in a computer and thatll tell you something.just aswell that it happens when you stop ,cant imagine the mechanic carrying a computer keeping up with you for long.lol.Na seriously error code 29 is a give away they will know what to do mate.
grse.mnky85 Offline
#4 Posted : Monday, 25 January 2010 9:00:42 AM(UTC)
grse.mnky85
ok thanks people
petaus Offline
#5 Posted : Tuesday, 26 January 2010 3:42:11 AM(UTC)
petaus
i would be looking at th egr valve maybe faulty or need a clean out ie carbon jammed it up remains open and when it should be shut at idle causing it to stall, a scan tool would help as you could watch the feedback change on the data.
if you let us know where you are im sure in this forum there is a mechanic from most states.
pete.
lildog Offline
#6 Posted : Thursday, 4 February 2010 7:53:50 AM(UTC)
lildog
Carbon in the throttle body butterfly will cause all the faults you have including a o2 sensor fault. Take off the intake tube and douse a rag with petrol open the throttle fully and clean the area where the butterfly rests.
