special-k Offline
#1 Posted : Thursday, 18 February 2010 5:09:06 AM(UTC)
special-k
Hi all just wondering if someone could please help me with a 5.0 I just bought as a builder.The guy I got it from tells me it is from a VQ stato which judging by the engine covers it is this era.The only confusing thing I found is when removing the crank it had 308 cast on it I thought that after the VK they all went 304.
The engine is VU595003 and cast near the timing cover is 14fo.
Any help would be great
Stu
#2 Posted : Thursday, 18 February 2010 6:00:42 AM(UTC)
vn - vs 304(308 crank casting is normal as far as I know)
Edited by user Thursday, 18 February 2010 6:01:14 AM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 18 February 2010 6:12:16 AM(UTC)
VU prefix is VN to VS 304 except VSIII ute and Statesman with 179kW engine
#4 Posted : Thursday, 18 February 2010 6:44:57 AM(UTC)
Yes AFAIK they left 308 on them.
#5 Posted : Thursday, 18 February 2010 8:01:31 AM(UTC)
The only thing different between a 308 & 304 crank is the offset machining of the big ends - the actual casting remained the same, so the 308 stayed.
That engine number is smack on for an early July 1990 EFI 5L.
I have 5 V8 commodores recorded with July 1990 build dates, and engine numbers ranging from VU5949xx to VU5956xx.
The casting number - 14th June 1990 - confirms that period, so it has come from either a VN or VQ, and the tag number (the end of the VIN) would be between L446xxx & L449xxx.
special-k Offline
#6 Posted : Thursday, 18 February 2010 8:22:32 AM(UTC)
special-k
Thanks very much for the help guys.
#7 Posted : Thursday, 18 February 2010 6:37:24 PM(UTC)
Mick, all VU engines ive seen have had SVU prefixes, so its probably VN. At a stretch it may also out of an early build VG Holden S ute.
#8 Posted : Friday, 19 February 2010 5:19:23 AM(UTC)
I have recorded a couple of July 90 built HSV VQ SV90s that have VU prefixes - I think SVU was only very early VQ motors, and was finished by this period.
Mr.Jones Offline
#9 Posted : Friday, 19 February 2010 5:53:21 AM(UTC)
Mr.Jones
Mick my engine is SVU613051 a little later than the first engine in this thread.
Leroy
"Planet earth is the asylum to which the rest of the universe sends its lunatics"
Voltaire
Voltaire
