bronsonHX Offline
#1 Posted : Tuesday, 23 February 2010 3:19:40 AM(UTC)
bronsonHX
i was driving along the other day at 100 when my speedo started bouncing between 90 - 100. i wasnt slowing down or speeding up or anything, and now it is permanently out, but the amount it is out by seems to get bigger each drive. now when it says 60 i am doing around 100. its definately not safe, particularly for my wallet if i get caught going over. and now my odometer is slow too, i drove 50 kms today and it said i did about 30. any ideas on what it could be and how to fix it?
Keeo Offline
#2 Posted : Tuesday, 23 February 2010 3:48:08 AM(UTC)
Keeo
As having just gone thru speedo dramas myself check simple things first like the plastic drive gear in gearbox if your car has one.It could be stripped and not spinning.-cheers keeo
#3 Posted : Tuesday, 23 February 2010 4:37:52 AM(UTC)
ive had the same problem too, it was the speedo drive gear stripped
bronsonHX Offline
#4 Posted : Friday, 26 February 2010 3:31:09 AM(UTC)
bronsonHX
had a look today, its not the drive gear its whatever is meant to turn the drive gear that is stripped..any advice?
#5 Posted : Friday, 26 February 2010 5:02:55 AM(UTC)
quick fix is to get a tacho and a mate to drive with you and write down rpm vs actual speed,this wont change.then fix your speedo later and youve still got a tacho....cool?
bronsonHX Offline
#6 Posted : Friday, 26 February 2010 7:05:04 AM(UTC)
bronsonHX
that is a quality idea, thanks jim. one snag is i dont have a tacho so this will end up costing me around 100 anyway haha, but i have wanted one for some time so thanks for giving me an excuse to get one
