retroHQ Offline
#1 Posted : Thursday, 25 February 2010 7:36:42 AM(UTC)
retroHQ
Hi all,
I am about to go look at a HX van and was wondering if it is a Sandman as the owner says (just like to know for piece of mind)
Heres all the ID tags from the car. Thanks in Advance!
#2 Posted : Thursday, 25 February 2010 7:52:06 AM(UTC)
It could be, but more likely not. GVW looks like 2200kg on the ADR plate and that means if it is a Sandman its an XU3 thus is a difficult proposition to identify. Given the tags are off the car id also be wary, and wouldnt buy it without a very good check of the shell, unless its very good value.
retroHQ Offline
#3 Posted : Thursday, 25 February 2010 11:14:50 AM(UTC)
retroHQ
The car is in pieces and needing a full rebuild. I believe its a factory 253, 4 speed and the colour is Mandarin Red.I will be looking at it tomorrow
I was able to get these pics as well. I dont mind a bit of hard work but I want to make sure Im working on the real thing!
Absinth Offline
#4 Posted : Thursday, 25 February 2010 11:22:22 AM(UTC)
Absinth
19v trim code says its not a Sandman.
#5 Posted : Thursday, 25 February 2010 5:09:55 PM(UTC)
Absinth is correct. I missed the 19V trim code, read it as 18V on first glance. I was sold on it not being a Sandman by the 2200kg GVW, but 19V trim nails it.
retroHQ Offline
#6 Posted : Thursday, 25 February 2010 8:20:39 PM(UTC)
retroHQ
So this origonal sandman with 19v trim is not real
either? Can someone tell me what 19v means? It stumps me because I didnt think that HX Panel vans came out as a 253 4 speed, mandarin red that werent sandmans? Anyway, thankyou for the info, you saved me a lot of moey and heartache :)
http://www.automerchant....olden_Sandman_Panel_Van/
GeeR Offline
#7 Posted : Thursday, 25 February 2010 10:09:17 PM(UTC)
GeeR
19V denotes as youve probably realised the trim colour, pretty sure 19V in an HX is black vinyl.
I think the correct trim codes for HX are 18V, 60A, 65A and 67V.
People, quite honestly at times Im sure, think they have a Sandman for sale. However if its important to you to be buying the genuine article read back through this thread from the beginning to learn how to identify them.
___________________________
WTB:
- HQ-Z standard rims
- HQ coupe front windscreen mouldings
- HQ ute antique brown trim - any pieces!
WTB:
- HQ-WB(?) bench seat 4-speed shifter
- HQ-WB ute rear window
- HQ-WB standard rims
- HQ-HX coupe front windscreen mouldings
- HQ-HX coupe door mouldings (the stainless one running along top of door exterior)
Jvanner Offline
#8 Posted : Thursday, 25 February 2010 10:52:01 PM(UTC)
Jvanner
its missing the side bits of flat steel that holden spot welded to the sides to hold up the full hood lining.
#9 Posted : Friday, 26 February 2010 2:06:15 AM(UTC)
Its a HJ, not a HX. Sandmans got 18V for black in HX/Z, normal Holden spec got 19V. In HJ all base models (Holden spec) got 19V when black ordered, only Kingswood got 18V.
#10 Posted : Friday, 26 February 2010 5:00:03 AM(UTC)
Pig in a poke.
#11 Posted : Friday, 26 February 2010 6:07:54 AM(UTC)
my advice to you is too buy smarter, spend more initially and you will save cash and heartache in the long run
#12 Posted : Friday, 26 February 2010 6:22:04 AM(UTC)
Good advice ...we wreck...start building from scratch it never seems to stop sucking
money ,your dead right!I wished I did that., still im nearly there.
Edited by user Friday, 26 February 2010 6:23:11 AM(UTC)  | Reason: Not specified
