toddyg Offline
#1 Posted : Monday, 8 March 2010 2:13:04 AM(UTC)
toddyg
found transmission fluid in jelly form stuck in trans filter in my powerglide.is this normal or something more sinister.actually looks like strawberry jam blobs stuck in filter
Casper Offline
#2 Posted : Monday, 8 March 2010 3:03:24 AM(UTC)
Casper
If you mix a mineral engine oil with a synthetic engine oil, youll get that.
Im not sure about tranny oils though?
Is there any silicone anywhere on the trans?
#3 Posted : Monday, 8 March 2010 4:00:30 AM(UTC)
drain it and flush an start again,check every now and then,also use the same fluid everytime,ps dont know what caused it but flushing should fix it.
toddyg Offline
#4 Posted : Monday, 8 March 2010 5:31:02 AM(UTC)
toddyg
no silicone,a few metal shavings and white flakes
#5 Posted : Monday, 8 March 2010 10:00:07 AM(UTC)
m daughters brakes went the same, i suspect it is water.
the flakes of metal dont sound too good though. the flakes are probably from aluminium the shavinghs may be bearings.
