postman_warren Offline
#1 Posted : Wednesday, 10 March 2010 8:09:04 PM(UTC)
postman_warren
my question is what is included in the hr front end reconditiong pack i wil be putting a hr front end on my eh also what would the quality be like. thanks warren
les Offline
#2 Posted : Thursday, 11 March 2010 12:22:16 AM(UTC)
les
Contents of HREHXMKIT
15-3146 MONROE SHOCKS FB-HG FRONT GT GAS 1 PAIR
2761 WHEEL BEARING KIT FRT LATE FE-HX 2 EA
440005 SCREW DISC BRAKE ROTOR HD HR 10 EA
7426375 HOSE BRAKE FE-HG WITH DISC BRAKE 2 EA
7427938 SUPPORT IDLER ARM FE FC FB EK EJ 1 EA
9932810 BALL JOINT UPPER HR-WB LC-UC TOR 2 EA
9943967 BALL JOINT LOWER HR-WB LC-UC TOR 2 EA
BKLC4 BUSH KIT FRONT SUSP LOWER EH UTE 1 KIT
BKUC4 BUSH KIT FRONT SUSPENSION UPPER 1 KIT
DBA001 DISC ROTOR LONGLIFE FRONT HD HR 2 EA
FEK5 KIT FRONT END MOUNTING RUBBER EH 1 KIT
HTGR0005 PENRITE HIGH TEMP GREASE 500GM T 1 EA
M38610 TIE ROD END OUTER 48 - EARLY HG 2 EA
VS10109 KIT DISC BRAKE CALIPER SEAL HD H 2 KIT
This page was generated in 0.529 seconds.
