AGRO Offline
#1 Posted : Thursday, 11 March 2010 8:01:13 AM(UTC)
AGRO
Hi
Just wondering if there are going to be any fuel sender's made for a HZ 308 van with factory a/c?
Mine has the 2 fuel hoses going into the sender.
75 HJ Sandman Pano
78 HZ BO6 Pano
les Offline
#2 Posted : Friday, 12 March 2010 2:44:09 AM(UTC)
les
The only one we do not have is part number 9929200 which is probably the one you are after. It suits HZ panel van , ute 5.0 litre with air con. We have no plans to make this part in the near future .
Les
AGRO Offline
#3 Posted : Friday, 12 March 2010 5:38:44 AM(UTC)
AGRO
BUGGER!!! :(
But thanks anyway
75 HJ Sandman Pano
78 HZ BO6 Pano
Tour Director Offline
#4 Posted : Wednesday, 9 June 2010 7:16:38 AM(UTC)
Tour Director
We have finally found a secondhand fuel sender unit sample with the two pipes that might be suitable to copy to make new sender units, however this will take a few months as they have to make a new unit and then it has to be tested before any production.If it is completed you will be advised.
AGRO Offline
#5 Posted : Thursday, 5 August 2010 7:08:56 AM(UTC)
AGRO
Thanks.
I'll eagerly wait to hear how this goes.
sandman502 Offline
#6 Posted : Sunday, 2 June 2013 2:36:27 PM(UTC)
sandman502
Hi. I Know this is and old thread, but have seen senders with air con available now. Just wondering do I need to use this sender. I have removed factory air con and replaced with aftermarket vintage air unit under dash. Engine is changed to LS and fuel pump is now electric.
Any info much appreciated and thanks in advance.
#7 Posted : Tuesday, 4 June 2013 6:47:53 PM(UTC)
Tour Director
This has been answered in the technical forum.Due to the many changes from the original vehicle specifications it requires care in selecting the correct sender unit.Expert advice should be sought.There have been some additional sender units added to the range including two pipe style models.
This page was generated in 0.272 seconds.
