nessyhk Offline
#1 Posted : Wednesday, 17 March 2010 3:40:42 AM(UTC)
nessyhk
Can anyone let me know what is needed to convert hk drum to hq disc. If ok ,will calipers and rotors fit. Also will a standard hk power booster etc be ok
Nessyhk
Built not Bought
Nessyhk
Built not Bought
#2 Posted : Wednesday, 17 March 2010 6:35:01 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
HQ-HJ stubs and calipers. Swap to other side so that calipers are on the front. Probably fit new discs, new wheel bearings and rebuild the calipers whilst you are there. New discs arent very dear and come with bearing races as well, about $60 each. You could probably order them with HK stud pattern too if you want!
Fit HQ rear wheel cylinders off a front disc car (cheap as chips new).
HK-HG disc brake booster to suit your car, and pedal to suit if yours doesnt work with it.
HQ disc brake master cylinder.
Probably get new front brake hoses and rear brake hose made up while you are at it. Bebco Automotive in Sydney make these to order. They can rebuild your calipers too, and Terry keeps original HK-HG or HQ style master cylinders in stock fully rebuilt, or just get a new PBR one.
Blow the lines out with air, and bleed it all up with new fluid. If you cannot bleed brakes get someone who knows what they are doing to help you, as you should always do with brake stuff.
nessyhk Offline
#3 Posted : Thursday, 18 March 2010 6:11:21 AM(UTC)
nessyhk
Thanks hk1837 will be swapping to hq by the sounds of it
Nessyhk
Built not Bought
Nessyhk
Built not Bought
htmunro350 Offline
#4 Posted : Monday, 22 March 2010 7:58:05 AM(UTC)
htmunro350
hi nessy i have a spare set of hq discs if u r interested give me a call or call around
cheers shaun
cheers shaun
cheers shaun
#5 Posted : Thursday, 25 March 2010 6:59:45 AM(UTC)
Id just buy them new. About $50-$60 each with bearing outer races.
This page was generated in 0.083 seconds.
