mrtf Offline
#1 Posted : Saturday, 27 March 2010 1:41:24 AM(UTC)
mrtf
The grill on my EH rattles and is loose when you touch it.
How do I tighten up the individual slats ?
Hang on help is on its way !
adam PERTH Offline
#2 Posted : Saturday, 27 March 2010 2:18:51 AM(UTC)
adam PERTH
twist the tags on the inside of the slats with a pair of pliers to 1/4 turn.
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
Utility8 Offline
#3 Posted : Saturday, 27 March 2010 3:14:44 AM(UTC)
Utility8
Adam is right, but you will not be able to access all the tags. A mild steel, 3/8 bolt with a 90 degree bend in it & a slot cut into the end with a hacksaw will allow access to the tags toward the end of each slats. Easiest access is by first removing the bonnet catch panel above the grill. Try to only bend the tags in the same direction that they have already been fitted.
Jump onto the Qld EH Club Forum for plenty of EH/EJ specific info.
http://www.ejehclubqld.com/ehclub/index.asp
Utility8
Edited by user Saturday, 27 March 2010 3:16:43 AM(UTC)  | Reason: Not specified
utility8
peter_flane Offline
#4 Posted : Saturday, 27 March 2010 3:22:21 AM(UTC)
peter_flane
It is not uncommon for some of the tags to be broken off. Yeah access by removing the top radiator panel and/ or the radiator will give you access to the tags.
If the tags are broken, then you may have to look for some replacement slats.
80569K Offline
#5 Posted : Saturday, 27 March 2010 5:56:00 AM(UTC)
80569K
Just give the tags a tiny tweak as per the previous. Stainless wont work harden as quickly as some other alloys but slowly does it, just enough to pull them in.
