#1 Posted : Tuesday, 8 March 2005 10:48:46 AM(UTC)
Hey I'm looking to buy either a VK Calais or a VL Calais (6cyl auto or manual, not fussed). I was wondering if someone could tell me the pro's and con's of each model, what the best year for the particular model is and if possible a comparison of the specs of each car. Also I hear the VK has a dodgey engine, what are the problems with the engine and what's it like dropping a VL engine in a VK? And how much would it cost?
Many thanks in advance.
#2 Posted : Tuesday, 8 March 2005 10:24:37 PM(UTC)
I reckon the VK has a great engine - an injected 202 - just a bit gutless. The VL had to suffer the ignomy of being the only Holden not to be fitted with a GM engine, plus VL's have their own problems like cracking heads and fragile gearboxes, not to ment
#3 Posted : Wednesday, 9 March 2005 12:09:41 AM(UTC)
Im fairly sure the vk's are lighter (ie better economy and better performance from the same power)
#4 Posted : Wednesday, 9 March 2005 2:37:31 AM(UTC)
Some food for thought
The VK Calais at the electronic "star wars" dash
which often malfunctions, and quite expensive to fix.
I agree with Byron the Injected 202 is a great engine,
very reliable, and also quite smooth. In terms of power
a VL 6 h
#5 Posted : Wednesday, 9 March 2005 3:32:33 AM(UTC)
Good advice. I have seen an EFI plated VK though with M20 on the body plate. I'd say it was a special order, as the 4-speed was not officially available on the VK EFI. These also have basically a V8 trimatic, with the 6cyl pump and bellhousing fitted.
#6 Posted : Wednesday, 9 March 2005 5:17:45 AM(UTC)
Ok well one more question, roughly how much would it cost to put a VL motor into a VK? Given I already have the VL's motor.
#7 Posted : Thursday, 4 August 2005 2:04:45 AM(UTC)
grab a vl calais turbo chuck a front mount pod a boost controler and the car will be knocking on the 13sec at 15psi
Guest (7)
