KRUPTOR Offline
#1 Posted : Tuesday, 13 April 2010 5:17:41 PM(UTC)
KRUPTOR
Hi,i got a open centre 10bolt salisbury diff in a HZ tonner.Was woundering if anyone can give me some pointers on a good welded centre.
I have a fair idea,i was going to remove the centre and remove crown wheel.Then weld the spider gears together and then weld a M12 or bigger nut into the centre of all the gears weld that all in.Then with 2 small pieces of 2/3mm flat weld that over the top of the nut either side.
Then clean the leftover weld.Will also degrease it before welding the centre....
Can it be done better????cheers
Utility8 Offline
#2 Posted : Tuesday, 13 April 2010 6:35:48 PM(UTC)
Utility8
Nope, that should work real good.
utility8
HQforme Offline
#3 Posted : Tuesday, 13 April 2010 11:12:20 PM(UTC)
HQforme
Just try to consider the balance of it when youre filling it with weld, and know that youll end up snapping axles. Still, lotta fun!
"Silly modern cars"
"Silly modern cars"
#4 Posted : Wednesday, 14 April 2010 4:41:25 AM(UTC)
are you trying to simply lock the diff? if so i know of a dead easy way to do it
