ht307munro Offline
#1 Posted : Tuesday, 27 April 2010 4:39:38 AM(UTC)
ht307munro
Is there any difference between a V8 and 6 cylidner crossmember / subframe for a HT (or HK / HG for that matter)? My HT monaro has a HK premier subframe which I want to change back to a HT subframe (may be able to source one from a HT ute). Will the cross member from the HK subframe fit to the HT subframe? Thanks.
Alex
Alex
#2 Posted : Tuesday, 27 April 2010 5:18:20 AM(UTC)
No, 6 and 8 are the same. Crossmembers will interchange between HK and HT/G. Id use the HT crossmember though, but make sure its not a real early HT, later is better as they have better geometry (upper control arms mounted 15mm or so higher).
ht307munro Offline
#3 Posted : Tuesday, 27 April 2010 5:39:30 AM(UTC)
ht307munro
Did all HT V8 monaros come with front disc brakes?
Alex
Alex
#4 Posted : Tuesday, 27 April 2010 5:47:09 AM(UTC)
No, AFAIK in some States you could get a V8 HT Monaro with drums, but all GTS got discs. HG was disc brakes standard with a V8.
ht307munro Offline
#5 Posted : Tuesday, 27 April 2010 5:57:53 AM(UTC)
ht307munro
I am in Queensland - any idea where I could get the information about which states had the HT V8 with drum brake fronts?
Alex
Alex
#6 Posted : Tuesday, 27 April 2010 8:15:21 AM(UTC)
Ben Stewart will know or Warren might also know. I got the States bit out of the Monaro Story. I thought discs as standard on V8 started in HG but I noticed Ben and Warren make the statement that it started in HT in some States.
kevin Offline
#7 Posted : Tuesday, 27 April 2010 9:49:33 AM(UTC)
kevin
i have an hg ute which im wrecking and its got a prem front on it where the subframe bolts up on the bottom it has 2 brackets that are bolted on there that come back about a foot or so with different holes could someone tell me what they are for i thought maybe a different gearbox x member but im not sure i dont know alot abut hg ect thanks
kevy
kevy
#8 Posted : Tuesday, 27 April 2010 7:01:23 PM(UTC)
If its what I think you mean that is standard for HT and HG (except for a few Chev manual HTs) and it is where the gearbox crossmember bolts to. The brackets arent bolted on though, but welded or part of the front subframe.
