Browno Offline
#1 Posted : Tuesday, 18 May 2010 6:40:49 AM(UTC)
Browno
buying a ek holden ute has no seat belts and is unregisted will i have to put seat belts in for rego
Drive It Like You Stole It......Drive it like you own it
castellan Offline
#2 Posted : Tuesday, 18 May 2010 6:51:14 AM(UTC)
castellan
No you don't have to.
because it was made before that ADR law came in.
But the cops may pull you up more often if you don't have them on. but they can not bust you for it.
peter_flane Offline
#3 Posted : Tuesday, 18 May 2010 7:40:15 AM(UTC)
peter_flane
As long as it is not modified in any way, then you dont have to fit seat belts. If they have ever been fitted you cant take them out though.
Browno Offline
#4 Posted : Wednesday, 19 May 2010 6:04:33 AM(UTC)
Browno
how hard is it to put seat belt in?
adam PERTH Offline
#5 Posted : Wednesday, 19 May 2010 7:37:21 AM(UTC)
adam PERTH
i think the ADR for seat belts was 7/70?
was it?
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
adam PERTH Offline
#6 Posted : Wednesday, 19 May 2010 7:38:52 AM(UTC)
adam PERTH
[quote]Originally posted by Browno
straight forward, buy a new set of retractables.
you get all the nuts and bolts ets.
all you need is a drill
WANTED:
#7 Posted : Wednesday, 19 May 2010 6:09:43 PM(UTC)
In NSW they've made it retrospective.
All cars from Jan 1965 onwards must have at least 2 front seatbelts, even HDs & early HRs, which didn't get them originally.
The best argument against democracy is a 5 minute conversation with the average voter.
80569K Offline
#8 Posted : Wednesday, 19 May 2010 6:37:51 PM(UTC)
80569K
Without having looked into it, is there an inertia reel setup you can buy which bolts up to the original bolt locations HR HK etc and are you allowed to fit said setup to holes you would have drilled yourself, eg Browno's EK?
