fitzsi Offline
#1 Posted : Friday, 21 May 2010 2:03:31 AM(UTC)
fitzsi
Can anyone tell me what pushrod length they have used to get the rocker moving onto the center of the valve tops.
I have AFR aluminium heads and Yella Terra roller rockers.
Have ground an old pusrod down and ground the head round to get what I think is the correct length which is 193 mm or 7 5/8 long.this is about 4 mm shorter than the standard pushrod length.
ITCH Offline
#2 Posted : Friday, 21 May 2010 3:58:00 AM(UTC)
ITCH
All depending on ur cam heads and block etc , its a bit hard to say, so check this out :http://www.carcraft.com/techarticles/116_0401_setting_pushrod_length/index.html
< Gotta Luv It!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
petaus Offline
#3 Posted : Friday, 21 May 2010 4:36:55 AM(UTC)
petaus
all depends on a lot of things, the article above is a good explanation, basically at half lift you want the roller tip in the centre of the valve, lenght depends on cam base circle block deck height, head deck thickness.
pete.
fitzsi Offline
#4 Posted : Friday, 21 May 2010 11:36:11 PM(UTC)
fitzsi
Thanks.Made an adjustable push rod and measured it from there.
