#1 Posted : Monday, 24 May 2010 4:55:45 AM(UTC)
Do HQ's use exactly the same Monaro script badges on the front guards as the hj hx hx Monaro badges?
What are the RareSpares repro ones like . . any good?
59 Cadillac Coupe Deville
74 HQ GTS4 308 Cyan Blue (should be Orchid Metallic)
74 HQ GTS4 350 Barbados Green
06 Nissan 350Z roadster
#2 Posted : Monday, 24 May 2010 6:48:12 AM(UTC)
yes but are red ,Hj-X are black some are ok but originals fit better.
#3 Posted : Tuesday, 25 May 2010 5:06:12 AM(UTC)
In HQ red for GTS, Black for Monaro, in HJ and HX they have the red ones as they are all GTS. (LS have no paint fill)
Warren
#4 Posted : Tuesday, 25 May 2010 5:54:21 AM(UTC)
HQ `monaro` is red check your brochures , yes HJ appears red too its HX thats black.
#5 Posted : Tuesday, 25 May 2010 6:36:22 AM(UTC)
Ok, so the red ones would be interchangeable, same part numbers.
Thanks guys
#6 Posted : Tuesday, 25 May 2010 4:38:10 PM(UTC)
Black PN 2814805
Red PN 9930243
Both used in HQ.
So red on Monaro and black on GTS?
28 part numbers are intro in 71, 99 in 72, so by your logic cloudy GTS will have Monaro badge from 71 and Monaro coupe gets Monaro badge in 72 or later. I thought it was the other way.
Personally I would not trust a brochure, as most is drawn. (check 72 brochure with all the headrests drawn on)
Waren
jabba Offline
#7 Posted : Tuesday, 25 May 2010 6:18:09 PM(UTC)
jabba
My 4 door 1974 HJ GTS has black script monaro on the front guards. But it was apparently repainted in 98 with HX blackouts, so can't guarantee they are original.
#8 Posted : Tuesday, 25 May 2010 6:43:23 PM(UTC)
Warren, both the red & the black badges are listed in the late HQ parts book as fitting the GTS, maybe the 9930243 red badge is for the 1973 upgrade.
The best argument against democracy is a 5 minute conversation with the average voter.
HJHeaven Offline
#9 Posted : Tuesday, 25 May 2010 11:50:38 PM(UTC)
HJHeaven
Both my current HJ and my ealrier HX had the red script (and red GTS badges for the front).
I dunno so much about the HJ but i know the HX was absolutely ridgy didge when i got it (second owner).
Just to confuse things.....
Mark
A GTS/4 is a monaro - so nuuur
#10 Posted : Wednesday, 26 May 2010 1:43:12 AM(UTC)
Terry,
71 GTS do not have a Monaro badge on them, only the Monaro coupe and LS have Monaro badges in 71. In 73 the GTS receives Monaro badge on front guard and the 350 designation removed from the GTS 350 front guard.
Warren
D. A. Barnes Offline
#11 Posted : Sunday, 6 June 2010 1:30:42 AM(UTC)
D. A. Barnes
The Monaro Bible says the badges on GTS are red so I would believe that before any parts catalogue or any self proclaimed guru. All correct cars I have seen have red badges on them also. Red is the answer here.
