#1 Posted : Monday, 31 May 2010 12:50:57 AM(UTC)
the auto in my sister in laws VN (V6) is having problems shifting gears
it will drive fine til it's time to change gears but it will just hold it's revs and shudder a little bit for a few seconds before shifting up a gear
it does this through all gears
any ideas what is causing this? what would i do to fix it?
#2 Posted : Monday, 31 May 2010 5:47:41 AM(UTC)
clutch pack?(if they have them)modulater?torque converter?
Jim in Adelaide...WTB CENTER LINE AUTO DRAGS 15X7 UPTO 8.5 WIDE.
#3 Posted : Monday, 31 May 2010 5:53:03 AM(UTC)
i'm hoping for a quick simple fix, cause i'm the silly sucker who'll have to fix it (again)
for some reason i'm the 1 in the family who only gets visits when there cars need fixing, Grrr...
#4 Posted : Monday, 31 May 2010 6:02:17 AM(UTC)
AT least if you fix their car properly ,you dont see em for ages....lol
#5 Posted : Wednesday, 2 June 2010 5:03:53 AM(UTC)
err.. the problem is now MUCH worse!!!
it won't change gears now, it just gets to about 4000rpm and serges and shudders, it think the gear box is buggered
she rang a local auto gearbox dude who said the box is stuffed and wouldn't be worth repairing
he said he could supply and fit a good second hand box for $700, this is too much for her to afford so it looks like i scored myself a gearbox change job (Grrr)
so... is a auto box in a VN (V6) easy to change? iv'e done plenty of HQ boxes would it be as easy as that?
would i just remove the motor/box as 1 unit swap the box then replace as 1 or is there a easier way?
any advice would be apreciated
petaus Offline
#6 Posted : Wednesday, 2 June 2010 5:12:45 AM(UTC)
petaus
hi dave, i did not think it was savable, i would drop the pan see whats in their and make sure filter is not blocked, if you going to pull box out you will want to drain the oil anyway, dont pull engine and box out can be done underneith on the ground no real differnt to a v8 hq.
when fitting new box hold the shifter bar with a shifter while tighening the nut up you dont want to bend the linkage inside the box, i learnt the hard way lol.
pete.
