classic oz wreck Offline
#1 Posted : Friday, 4 June 2010 2:34:07 AM(UTC)
classic oz wreck
part number h1006...nicely done product but its missing its springs..if a customer is going to buy these its because they are missing as they really dont wear or break...are you going to do the springs to put in the package or didnt you know that they need them?
if you werent aware and need a sample i will send you one..
www.classicozwreck.com.au
Tour Director Offline
#2 Posted : Friday, 4 June 2010 4:48:45 AM(UTC)
Tour Director
We haven't got around to the springs yet as we are still finalising the remaining rods to be made.I have a couple of samples so it should be relatively easy to add them to the kits.Thanks for advising us on an improvement to an existing product.
#3 Posted : Friday, 4 June 2010 9:58:50 PM(UTC)
classic oz wreck
no probs...i sell your products and i am happy to give you some feedback from the ground level if you guys are serious about improving your quality...
part number 7430631...the bearing is half the size it should be and its not round on the inside,i had to use a second hand genuine bearing to get it to fit..also there is no wiring plug on the end therefore you need to unpick one from a second hand unit...bad luck if you dont have a second hand unit to get the plug and bearing from...i have fitted these and they work well but for the price need to be complete..
part number 2818877..very nicely presented product if you are not doing a correct restoration..
i purchased one of these to fit to my panelvan so i wasnt worried about factory correct...it does not fit,you cannot shut the bonnet..
there is a long story to go with this...shortened version..sent back for credit...simply does not fit ..
#4 Posted : Saturday, 5 June 2010 1:08:36 AM(UTC)
Tour Director
Thanks for the information on the rods and note the springs are being considered and under quotation now.The indicator switch is also in our program to find a new supplier and will try and include the wiring plug. The bearing originally came from the USA and they have stopped producing it so we are trying to locate that too.
The shroud is already under inspection to resolve as the original sample was fitted to a vehicle and an ADRAD core.We will advise the results on this when known.
This page was generated in 0.309 seconds.
