Hindmaster Offline
#1 Posted : Thursday, 10 June 2010 11:59:17 PM(UTC)
Hindmaster
Hi - I have an original condition HQ wagon (202 trimatic) which runs beautifully, but I am having trouble getting it started on cold mornings. It turns over OK (until the battery starts losing power), but doesn't want to start on the cold mornings. Any suggestions would be much appreciated ...
#2 Posted : Friday, 11 June 2010 12:17:02 AM(UTC)
maybe the choke needs adjusting , what cond is the carby in, some cars are tempermental, I had a HQ that would not start if the choke was used and another that was opposite.
Hindmaster Offline
#3 Posted : Friday, 11 June 2010 12:53:42 AM(UTC)
Hindmaster
Choke is working OK as far as I can tell, and I use it to start when it is cool outside. I haven't looked at the carby closely, but the engine runs and idles well when it has warmed-up. Cheers ...
#4 Posted : Friday, 11 June 2010 1:51:49 AM(UTC)
Check it is getting 12V to the coil during cranking and 9V running. It may be a poor connection in a connector eg at the firewall joint or ignition switch etc.
If I were you I'd ditch the points dizzy anyway and fit one off a 6cyl WB or VC-VK (VK EFI only, not carby). It will bolt straight in, but you will need the coil as well, and bridge the start/run wires at the ignition switch together so the coil gets 12V always.
#5 Posted : Friday, 11 June 2010 4:23:01 AM(UTC)
Also check fuel is not draining back to the tank ,and by time it get up, your battery has run too far down.EASY TO CHECK ,just pour fuel in the carby BEFORE you try it for the first time on a cold morning.
Jim in Adelaide...WTB CENTER LINE AUTO DRAGS 15X7 UPTO 8.5 WIDE.
#6 Posted : Friday, 11 June 2010 4:29:49 AM(UTC)
winter is unkind to batteries, i'd check the battery
most battery shops do free battery checks, i'd suggest getting your battery tested
other than that i'd agree with byron (HK1837) the electric dizzy is the best thing to do for you engine
#7 Posted : Friday, 11 June 2010 4:35:35 AM(UTC)
Whilst an dizzy upgrade would be good ,I dont think its the problem here.
battery/carby/fuel.its one of those.Otherwise it wouldn't run good anytime.
petaus Offline
#8 Posted : Friday, 11 June 2010 4:55:34 AM(UTC)
petaus
id check battery voltage while cranking, make sure does not below 9 volts while cranking.
pete
#9 Posted : Friday, 11 June 2010 5:05:55 AM(UTC)
omg...confuse the poor guy even more than he already is..just put a good battery in it and thats that!
they were a pig from day 1 when they were cold. we had one from new and my wise dad made up his own pre-heat pipe from exhaust manifold into the air cleaner, piece of copper pipe bent around the exhaust and drilled into the side of the aircleaner, once it started, after a min or 2 if was ok.
simple as that, he even made a few more for neighbours that had HQ'S when we they were newish
ITCH Offline
#10 Posted : Friday, 11 June 2010 5:06:58 AM(UTC)
ITCH
Cheers!!
< Gotta Luv It!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
petaus Offline
#11 Posted : Friday, 11 June 2010 5:28:41 AM(UTC)
petaus
i think itch is on the money, i can tell you from experiance that a 149 v16 detriot diesel starts well on this stuff lol
petaus Offline
#12 Posted : Friday, 11 June 2010 5:30:29 AM(UTC)
petaus
maybe its the stop light bulbs drawing more current in the cold morning??? lol
#13 Posted : Friday, 11 June 2010 5:31:33 AM(UTC)
this will start it
ITCH Offline
#14 Posted : Friday, 11 June 2010 5:46:04 AM(UTC)
ITCH
BOOM!!
Hmmmmm maybe not Wrecked !! hahaha
Cheers!
< Gotta Luv It!
#15 Posted : Friday, 11 June 2010 6:03:11 AM(UTC)
lucky you got there in the nick of time mate, precious cargo...
Edited by user Friday, 11 June 2010 6:04:12 AM(UTC)  | Reason: Not specified
#16 Posted : Friday, 11 June 2010 6:04:40 AM(UTC)
petrol in carby.
ITCH Offline
#17 Posted : Friday, 11 June 2010 6:07:10 AM(UTC)
ITCH
That was pure ASS she got outer that alive !!!! HAHA!!
Cheers!!
< Gotta Luv It!
ITCH Offline
#18 Posted : Friday, 11 June 2010 6:24:04 AM(UTC)
ITCH
I know a fella that's real good with carby's , he paints em up too.......
Blissy's GOLD Carby restorations ...... hahaha
cheers!!
< Gotta Luv It!
#19 Posted : Friday, 11 June 2010 6:28:08 AM(UTC)
roflmcaooooo.. BAHHHHHHHhahahahahahahah
GOLD!!!!!
petaus Offline
#20 Posted : Friday, 11 June 2010 6:37:28 AM(UTC)
petaus
ha wreck didnt they use that copper pipe at triblenka and austwhich?
