#1 Posted : Monday, 14 March 2005 1:11:00 AM(UTC)
I have an 88 EA Falcon with a re-conditioned centrepoint engine which is on gas, I was reading in a street machine mag that stock AU engines fetch slightly under a grand if you look hard enough, and stock BA engines minus ancillaries are about $1650. How hard would both of these engines be to drop in the EA... with all electricals and others which may need changing? And what would it be setting me back?
Thanks alot
#2 Posted : Monday, 4 April 2005 6:00:05 AM(UTC)
You probably have problems with cross member and clearance of the bonnet.
#3 Posted : Tuesday, 5 April 2005 7:08:35 AM(UTC)
BA Engine short block for 1650, ya dreaming try 6500
