#1 Posted : Monday, 5 July 2010 8:45:56 AM(UTC)
Here is a question for the Mexicans amongst us.
I have found a nice car down that way and almost took an early morning drive today to go and look at it.
I decided that it would be a good idea to do a Revs check on it so I went to the VicRoads web site for a look see.
The check came up stating that the car was a repairable writeoff.
Asked the seller how badly damaged it was & he says that he has no idea as he bought the car from a dealer two years ago.
Now my question is is this possible or am I being spun a porkie? I would have thought that it would not come up as a writeoff once a VIV check has been done and it would not be re-registerable without said VIV.
Can anyone shed some light on this for me?
80569K Offline
#2 Posted : Monday, 5 July 2010 5:51:25 PM(UTC)
80569K
A word to the wise Jim, at the first sign of any hiccup like that walk away and don't even think about it.
classic oz wreck Offline
#3 Posted : Monday, 5 July 2010 7:52:58 PM(UTC)
classic oz wreck
any vehicle that was insured and has gone thru an auction wether its been considerable damage or fresh water flood damage or uneconomical to repair is a repairable write off and is on the wovr...{written off vehicle register}..therefore when you do a revs it comes up and tells you that you should spend more money getting another check done thru auvis and they can tell you more i believe....if you dont like the idea of buying a vehicle that is on wovr keep looking and if you dont mind offer them lots lower than they are asking as its scarred for life....btw..if he bought it from a dealer he should have been told as its part of the motor dealers act that they must declare this...in nsw anyway..
www.classicozwreck.com.au
#4 Posted : Monday, 5 July 2010 7:54:57 PM(UTC)
classic oz wreck
to add to what i said above jim...if its a statutory write off it can never be reregistered in australia and if its a repairable write of it just needs an inspection but it never leaves the wovr.
#5 Posted : Tuesday, 6 July 2010 8:50:22 AM(UTC)
I buy a economically written off vehicle every 2 or 3 years, usually about 4 years old, with damages usually to the bolt on panels, so not much panel beatings required, I can bolt things on but not so good at panel work.
In WA they are quite happy to put them over the pits, there are no short cuts I have found, the vehicle must be roadworthy.
Don't know what would happen if a Victorian writeoff turned up.
As far as I can see, the NSW regulations were introduced to protect the dealers from competition, they prevent the ordinary guy from getting into a more modern and safer car.
This page was generated in 0.066 seconds.
