#1 Posted : Tuesday, 15 March 2005 5:46:34 AM(UTC)
At the moment I have a m21 4 speed, and wish to install a 5 speed.
Is there a 5sp box I can use without having to change anything, eg. tailshaft, bellhousing. A ford nine inch diff and a modified tailshaft are in the vehicle now to suit current gearbox.
classic oz wreck Offline
#2 Posted : Tuesday, 15 March 2005 6:52:28 AM(UTC)
classic oz wreck
you will still have to change bellhousing,clutch plate,modify crossmember and tailshaft if using a supra type box...
www.classicozwreck.com.au
#3 Posted : Tuesday, 15 March 2005 8:09:30 AM(UTC)
Send me an email. I've got a Supra conversion out of a HJ at home. Email address on my website, details in profile.
Holdenute Offline
#4 Posted : Tuesday, 15 March 2005 7:04:28 PM(UTC)
Holdenute
You could also go with a T5, but again you'll need to change everything you don't want to change. Talk to either Dellows (Sydney) or CRS in Vic.
Cheers, Steve.
Never late in a V8
Never late in a V8
#5 Posted : Tuesday, 15 March 2005 11:44:54 PM(UTC)
Was going to put a commodore T5 in the HQ Prem, it can be done, dellow arn't real keen on the idear as the shifter ends up near your hip, and you may have to modify input shaft as the T5 of the v6 has about the longest input shaft on market. ( they do hav
Holdenute Offline
#6 Posted : Wednesday, 16 March 2005 7:49:25 PM(UTC)
Holdenute
Should have added, a T5 from a 6cyl Falcon is the go, rather than Commodore ones. The input shaft is shorter, although you still need to cut a little bit into the floor rib.
Never late in a V8
Never late in a V8
#7 Posted : Thursday, 17 March 2005 2:14:50 AM(UTC)
Trans Diff in Victoria made a big bore version of the Aussie 4 speed.
I don't know if they are still around.
s
http://www.lycanthia.com
http://groups.yahoo.com/group/Lycanthia/
#8 Posted : Thursday, 17 March 2005 5:16:12 AM(UTC)
no 5 speed will just bolt up as far as i know.
as stated, go a supra box, purely for shifter location.
T5's aren't as tuff as the supra boxes anyway.
if it was me i would go a tricked out auto....but thats just me
Guest (6)
