jphick Offline
#1 Posted : Tuesday, 15 March 2005 1:25:22 PM(UTC)
jphick
Is it possible to put a HQ 202 engine into any of the different transmission options of the HZ---3/4 spd manual and the 3spd trimatic and turbohydromatic ?
.Are there potentional compatability problems that anyone has had experience with?
I realise this could be a stupid question but i,m asking it anyway,better to be sure than sorry!!
cheers, Paul
#2 Posted : Tuesday, 15 March 2005 7:03:19 PM(UTC)
The easy options, ie factory fitment for any red/blue/black 6cyl are:
3spd - crashbox or all synchro (M15).
4spd - Opel (M20), MC6 (UC), Aussie (M20,21,22), Saginaw (M21, M22) or a Muncie will basically fit where a Saginaw will.
5spd - Borg Warne
jphick Offline
#3 Posted : Tuesday, 15 March 2005 9:07:20 PM(UTC)
jphick
Thanks for info Byron,appreciated.I have found several 8 cyl Auto HZ,s,will that make any difference when swapping over to the 6cyl 202?Where would be a good place to find a list of possible adaptors? Will I need to have pollution gear fitted?Lots of
#4 Posted : Tuesday, 15 March 2005 10:25:52 PM(UTC)
The V8 trimatic won't bolt to the 202. It can be made to, but that involves changing the pump and bellhousing. You are better off buying a trimatic out of a HQ-VK. The best 6cyl box to get is a VK EFI one, which is basically a V8 box with the 6cyl pump an
jphick Offline
#5 Posted : Sunday, 20 March 2005 5:38:48 AM(UTC)
jphick
Nice one Byron,Cheers .More to look out for!
jphick Offline
#6 Posted : Sunday, 20 March 2005 5:59:13 AM(UTC)
jphick
Will it make any difference that the engine was new in 1999.?Is it possible the mount is on the head of the new 202?
#7 Posted : Sunday, 7 August 2005 5:44:30 AM(UTC)
Byron - "It's not easy to use a Commodore box if you intend using a column shift" - is it a pig to do and to use? and do you have the gear ratios for the 5spd options?
thanx for asking jphick
Guest (7)
